Ebay poly motor mounts...thoughts?
Old Mar 22, 2009 | 11:48 AM
GT-ER's Avatar
Never heard of revshift before and search showed nothing on them. Mine are shot, so what do you guys think? Should I try them out?
http://cgi.ebay.com/ebaymotors/ws/eB...m=150333669275
Old Mar 22, 2009 | 02:27 PM
uf20wop's Avatar
probably no good
anything like that on ebay is sketchy
Old Mar 22, 2009 | 06:04 PM
GT-ER's Avatar
Originally Posted by uf20wop
probably no good
It's not very complex to make a poly mount, I'm more worried about vibration. I don't mind if the steering wheel vibrates a bit but I don't want the whole car to fall apart either.
Old Mar 22, 2009 | 07:55 PM
xXHotelCrazyXx's Avatar
From a friends personal experience, he found polyurethane mounts to transfer engine vibrations throughout the car. He said he would never recommend them. Whats wrong with the ones you have now?
Old Mar 23, 2009 | 12:18 AM
DaveB's Avatar
Why do you think your mounts are shot?
Old Mar 23, 2009 | 02:54 AM
GT-ER's Avatar
The engine rocks so bad that the drivers side cat hits the floor. I put the engine brace sold on ebay ( stillen look a like ) and the cat does hit anymore but the engine feels very sloppy. My car has 90K miles so I wouldn't be surprised if they are shot.
Old Mar 23, 2009 | 12:22 PM
ttrank's Avatar
Grocery getter
I have a friend who has recently tried to purchase from them and is having a lot of issues. I would stay clear of this company.
They claimed to have them in stock for his GTO back on 3/6 and are still giving him the run-around.
Old Mar 23, 2009 | 01:09 PM
ttrank's Avatar
Grocery getter
I also see they make a Kinetix SSV style manifold with some pretty unrealistic claims:
http://www.revshift.com/intake.htm
In naturally aspirated applications Revshift intake manifolds are capable of producing as much as 10 psi positive pressure at the intake valve.
In naturally aspirated applications a 5% to 10% power increase is typical, in forced induction applications a 15% to 20% power increase is typical.
Old Mar 23, 2009 | 01:13 PM
WILLIE BEANS's Avatar
stick with oem mounts ??
Old Mar 23, 2009 | 01:47 PM
WOW that looks horrible also! Looks like it was produced in a HS sheet metal class
Old Mar 23, 2009 | 02:24 PM
GT-ER's Avatar
Wow...that website made me sad. Where is the cheapest place to get stock mounts?
Old Mar 23, 2009 | 02:43 PM
DaveB's Avatar
I strongly suggest you inspect the mounts to make sure they're not torn (engine mounts and tranny mount). These mounts don't wear out. They tear and I've never heard of annoying tearing one, except for a tranny mount. You say the cat hits the chassis, how's that possible? The cats have mounts that attach them to the tranny. Has your exhaust been damaged in such a way that it's bent the cat?
Old Mar 23, 2009 | 04:00 PM
GT-ER's Avatar
Worn or torn means I have to change them anyways correct? The cats are bolted to the tranny, and the tranny to the engine. When I accelerate the drivers side on the engine moves upward an odd amount. This causes the entire engine/tranny/cats assembly to move ( or rather twist ) and hit the chassis. I might just have one bad but I might as well change both if that's the case.
EDIT: wow...Riverside has them for $150 each...yikes...I thought they were cheaper. I guess it's time to inspect..lol.
Old Mar 25, 2009 | 01:27 PM
ttrank's Avatar
Grocery getter
Megan Racing also makes a engine/tranny mount kit. That brand name gets a lot of crap but from what I have been able to read so far their mount kit is very good.
Old Apr 20, 2010 | 01:37 PM
H0TEP's Avatar
Ordered a set of revshift "soft" poly engine mounts. I'm in no rush to install them but I'll provide updates on vibrations.
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
nanobotking
Oct 8, 2015 08:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
