Well i guess slight rattling in idle is NORMAL with VQ35DE engines?
Apr 17, 2009 | 03:59 PM
So i took my car to the dealership for " slight rattling of the engine when idling " and it came out as " perfectly fine ".
I've also noticed the same type of rattling on the loaner G35 with only 15k mileage they borrowed to me, as well as the two 08 Maximas (one with 26k mileage, the other has 16k) I test drove two days ago.
however....my friend has a G35 coupe with 50k mileage that doesn't rattle at all...
i guess the rattling is normal then ?
Reply 0
Apr 17, 2009 | 09:38 PM
Is it really a rattle, or more of a ticking noise? My engine ticks all the time...annoying when I walk up to my car when it's running & I hear it...but I don't hear it when I'm in my car.
Reply 0
Apr 17, 2009 | 09:48 PM
To be honest, i've heard it quite often too. I think with mine it's the a/c, but i have noticed it at idle.
My mom wanted a G35, so we looked at 3 '06's. I remember distinctly thinking "damn, do all g's rattle like this?" when i heard it idling as they pulled it up.
Reply 0
Apr 23, 2009 | 01:37 AM
my 03 G35 would rattle a little as well.
Reply 0
Apr 23, 2009 | 06:55 PM
If it's a metallic sounding noise I'm pretty sure it's the engine belts. If you haven't had those replaced in a long time I'd give it a shot - this would also explain why other models with the same engine make this noise.
Reply 0
Apr 23, 2009 | 09:59 PM
Could also possibly be the noise come from the valvetrain, which VQ is notoriously known for.
Reply 0
Apr 23, 2009 | 10:01 PM
Can you feel the rattle? Like a slight shaking?
Reply 0
Apr 24, 2009 | 12:52 AM
I get a rattle that's audible with the headlights or AC on.
Reply 0
Apr 24, 2009 | 01:07 AM
lucky, no rattle or ticking sound and no steering wheel or dash vibration when on D, and fully stopped at a light---thankfully. I had a 90 Galant 4 cylinder new, and when it was only 4yrs old or maybe 3 the damned car on D at a light vibrated (dash/wheel) so much that any girl within a mile orgasmed due to the vibrations.
I will check tomorrow again just to be sure--had the belts replace a few wks back too.
Reply 0
Apr 24, 2009 | 09:19 AM
A little noise is usual being that our motors have a timing chain instead of a belt. Also, they have solid valve train components which gives them a ticking sound.
Reply 0
Apr 24, 2009 | 09:58 AM
Not sure if this is your issue, but there is a Service Bulletin for this...
http://x.infinitihelp.com/forum/loca...d&pp=12&page=3
Quote:
ITB06-012
INFINITI; TICKING NOISE FROM ENGINE AREA
There is a ticking, clicking, thumping, or knocking noise heard in the passenger compartment at idle.
I don't have a way to convert pdf to image so I can't directly post the TSB here... But they basically say it could be the fuel feed hose and damper that'll need to be replaced.
Reply 0
Apr 25, 2009 | 01:36 AM
Quote: Not sure if this is your issue, but there is a Service Bulletin for this...
This is a different type of noise, generally heard in cabin but not from the exterior. I changed mine a few thousand miles ago.
Reply 0
Apr 25, 2009 | 01:45 AM
hah, so i'm not crazy after all. i took my car in to 3 different dealerships for the following:
1) rattling at idle
2) oil consumption
3) noisy lifters/rocker arms
all 3 dealerships said that nothing is wrong with my car. they said the rattling is cause by the triple flex flywheel and clutch. oil consumption is considered "normal" consumption. tapping/ticking noise in the driver side engine bay, they "can't" hear it. it's even audible to people who has no idea about engines..
Reply 0
Apr 30, 2009 | 07:16 PM
lifter noise
So it is normal for the lifters to be clacking like crazy? I just bought my car last week and didn't notice it.. i also didn't notice it on the 2 automatics i test drove.. get it home it's clicking pretty loud.
Reply 0
Apr 30, 2009 | 07:18 PM
Quote: So it is normal for the lifters to be clacking like crazy? I just bought my car last week and didn't notice it.. i also didn't notice it on the 2 automatics i test drove.. get it home it's clicking pretty loud.
man that sucks, they probably ran it low on oil at some point? time for a new motor
Reply 0
