oil filter for g35
Old Feb 25, 2010 | 03:11 PM
  #91
Swivel's Avatar
Moderator
Twilight, zero leakage issues in 3 years with the Wix 51356 (aka NAPA Gold 1356).
I loved my filter once, but it was dirty and uncomfortable, so I stopped.
Old Feb 25, 2010 | 05:47 PM
  #92
TwilightSedan's Avatar
Thanks a lot, was pretty certain everything would be fine with having a big 1356. Appreciate you sharing your experience. When it comes to your love for your filter though. How did you fit it in there? J/K. Napa Gold/ Wix/ Amsoil, seem to equal the best oil filters available. Time for me to pick up a box of 1356's.
Old Feb 25, 2010 | 08:25 PM
  #93
BuckeyeInMI's Avatar
I'm on my second Napa 1356 and no leaks whatsoever.
Old Apr 17, 2012 | 01:34 PM
  #94
Mr. Samster's Avatar
reviving an old thread.
i was looking up parts number for the wix/napa gold oil filter and it looks like they changed their parts number to wix 51358/ gold 1358. I was wondering should i buy the old filter(1356) or just buy the new one that they offer now?
Old Apr 18, 2012 | 09:49 PM
  #95
vqsmile's Avatar
Yep, just came across this myself today. I've actually been running the Wix 51365 or Napa Gold 1365 for well over 4 years now on my '07 sedan because that's what Wix recommended. Now, it seems they've changed their recommendation to the 51358.
This kinda sucks now because I've kept all my receipts from doing my own maintenance (for extended warranty purposes) over the years, and basically, if I ever have a problem going forward, I will now only have records showing that I was installing the wrong oil filter. WTH!
I know they work and all, I just hate to think that the dealership could have something to give me grief about now since Wix went and changed their recommendation without any reference to the old one being superceded; it's like they just ommitted any record of it ever fitting.
Here's specs on the new filter:
Detailed Description:
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782 in.
Outside Diameter (Top): 2.685 in.
Micron Rating: 14
Thread Size: 20X1.5 MM
By-Pass Valve Setting (PSI): 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=13/52
Burst Pressure (PSI): 265
Max Flow Rate: 8-10 GPM
Gasket Diameters:
Outside Diameter: 2.475 in.
Inside Diameter: 2.173 in.
Thickness: 0.233 in.
Most noteable to me were that, compared to the 51365, while the micron rating did improve from 19 down to 14, the max flow rate went down from 9-11 to 8-10, and burst pressure went down from 300 to 265. I guess this means it will flow less oil, but filter it better, although it could theoretically burst sonner than the old one.
Old Apr 18, 2012 | 11:36 PM
  #96
i actually went ahead and order the old model number through fleetfilters.com since they were alot cheaper than napa auto parts store and other online stores. at 4.84 a filter it isnt a bad price, but you do have to pay for shipping.
Old Apr 19, 2012 | 12:45 AM
  #97
vqsmile's Avatar
I saw their link too, but if you go to the next page of google results, you find this place: (I haven't used them yet, but I plan to check it out)
http://www.usafilterstore.com/mm5/me...vc?Screen=SRCH
They list your 51356 at $2.90 ea., and my 51365 at $3.25 ea.
Shipping is steep, but I planned to buy a bunch to distribute the per filter price a little better. Their price on the new part number 51358 is $4.67 ea.
Any of them are better than paying $8.00+ locally
Old Apr 20, 2012 | 02:04 PM
  #98
^ damn... lol i just did the calculation. That website is still cheaper by almost $20. i bought a total of 10 oil fitlers. 5 for me and 5 for my friend's civic.
Old Apr 26, 2012 | 02:04 PM
  #99
That's G's Avatar
I was just on the NAPA website and they recommend the shorter 1358, but it seems most people recommend the longer 1356?
What's the difference, if any?
Old Apr 26, 2012 | 09:13 PM
  #100
vqsmile's Avatar
One is supported by the manufacturer for failure, the other is not. That being said, I think either is going to work fine. Since I buy in bulk and I want to be able to show receipts for the appropriate filters, I will just get the new suggested part number. WIx tech support swears the filter is WAY more than adequate to handle the required filtration for the engine; even in the small form factor.
Old Apr 27, 2012 | 10:06 PM
  #101
That's G's Avatar
I went to O'Reilly Auto Parts by my house to see if they had the PureOnes and I ended up finding 2 Wix 51356 filters for $6 a piece. Didn't know they sold them. Feel like I scored
Old May 2, 2012 | 02:23 AM
  #102
bentotdagr3at's Avatar
Originally Posted by Gr8speed68
No offence but fram oil filters are garbage...what i mean by that is go buy 1 cut it in half and see whats inside...there absolute garbage u get what u pay for....IMO buy super luber or Wix...u kant go wrong
I wouldn't say all Fram filters are garbage. That is just complete ignorance. I'm a Wix user but i wouldn't diss Fram just yet. I'm running my next oc with their ultra filter and will do an oci at 6k miles. Last oci i had some silicate in both the G and Xterra.
Their ultra filters are one of the best ones out there. A few praises from BITOG and other forums.
Old Jun 17, 2012 | 12:34 AM
  #103
g35nit's Avatar
oil
Originally Posted by BH818
I'm using royal purple now
I know a shop in Van Nuys (Sourthern California)
they sell them for
"Eneos oil with factory filter, washer and 5W-30:$54.95
Eneos oil with factory filter, washer and 5W-20 or 0W-20 (5 Qts.)$64.95
Eneos oil with factory filter, washer and 0W-50 (6 Qts):$74.95"
whats up man im in the 818 as well. im in burbank or victory and kester, van nuys. im using 10w 30 is that ok? i just diy oil changed today got a wix 57365 filter and castrol edge ful syn 10w 30. im asking cuz im noticing everyone using 5w 30.
Old Jun 17, 2012 | 01:10 PM
  #104
vqsmile's Avatar
Well, that's because 5W-30 is what's recommended. You should be using 5W-30 too. Why wouldn't you?
Old Jun 17, 2012 | 02:59 PM
  #105
g35nit's Avatar
Thumbs up
I got the car not too long ago and since the first time I did the oil change the guy at the autoparts store recommended 10w 30 if I drive my car hard. I didn't know about this site but I'm glad I found it :-) bump thx dude will change up in 3000 miles
