compatible
Old Apr 20, 2009 | 12:26 PM
G3.5AT's Avatar
compatible
would it be ok to run
http://store.newlevelmotorsports.com/lrtyhyvosyt.html
and the
http://www.forgedperformance.com/store/home.php?cat=294
think they will have any problems with each other?
Old Apr 21, 2009 | 11:57 AM
bbs350z's Avatar
no they wont run into problems, i have the dli on my z which connects to only the coilpacks and main harness. the voltage stabilizer is essentially a ground kit if im not mistaken. they will work, but make sure you wire up the dli properly
Old Apr 21, 2009 | 12:10 PM
G3.5AT's Avatar
Thank you for a good answer I greatly appreciate it.
Old Apr 21, 2009 | 06:11 PM
Texasscout's Avatar
They shouldn't buck each other at all. The HKS is a proven technology, however, I think you are wasting your money on the Voltage "regulator". The car has one already built in. You also don't want to "regulate" the voltage going IN TO the battery. The regulator/computer in the car varies the voltage as the battery charges, starting out high (up to 15 volts) and then tapering off to a nominal charge voltage (13.8volts). Now if you are running something that is very voltage sensitive, that's a different kettle of fish.
BTW, there are always a few *******s on every forum, don't let them get you down. Cream rises to the top, but so does the scum.
Old Apr 21, 2009 | 07:31 PM
G3.5AT's Avatar
think i am just better off with the HKS then?
Old Apr 21, 2009 | 09:50 PM
snotf's Avatar
yeah, that sun thing just seems like a waste.
Old Apr 22, 2009 | 08:14 AM
Mustang5L5's Avatar
What other mods do you have to justify it?
If you are near stock, i'm not so sure it would justify a $500 ignition upgrade.
Now if you are FI or have a ton of N/A mods..then i could see it.
Old Apr 22, 2009 | 02:04 PM
ttrank's Avatar
Grocery getter
Not worth it with better options out there for more gains.
Old Apr 22, 2009 | 02:15 PM
G3.5AT's Avatar
Like what?
Old Apr 22, 2009 | 04:00 PM
Texasscout's Avatar
Orisis (sp?) or Technosquare ECU reprogramming for one. High flow cats, Motordyne MREV2 lower manifold (made the MOST noticable difference on my 05' RevUp). Some say that replacing the rear diff with lower gears really perks things up.
Old Apr 22, 2009 | 04:49 PM
G3.5AT's Avatar
Well its a 5AT. I have the Stillen intake and z-tube, Stillen grounding kit, Motordyne 5/16" iso-thermal plenum spacer, and the coupe midpipe. So other than FI and the valve body and trans cooler. What should I go for? I plan on a ECU reflash aswell.
Old Apr 22, 2009 | 04:51 PM
G3.5AT's Avatar
It is 2003 sedan RWD. and most of the diy ecu reflashers exclude my year so I don't know what to do. So I guess the shop I go to could do it.
Old Apr 22, 2009 | 04:59 PM
ckg35's Avatar
Originally Posted by G3.5AT
I think I did some reading a few years back about the Sun Hyper-Voltage System and there were a few that reported favorable results. If I remember correctly, I asked Gordgee (GroundingGear) about testing they had done with similar systems, but I don't remember what they found. I know I decided against trying one however based on the information that I gathered. You could try shooting a PM off to Gordgee to see what he says. They've done extensive R&D on this and hyper-ground kits in the past.
stratous01
Oct 7, 2015 10:19 AM
Dannyy06
Sep 25, 2015 11:32 AM
youngdip631
Lighting
Aug 31, 2015 09:13 PM
Pcruz
Aug 12, 2015 07:46 PM
ClwMike
Jul 23, 2015 12:55 PM
