pulleys with vortech
Old Apr 12, 2011 | 10:46 PM
show2nite's Avatar
Originally Posted by bigc
You and I have similar mods and are at the same power level. My car made 408whp when I the 2.87 pulley on so it should get you there. I'd check with your tuner beforehand, however, as the 2.87 creates a good amount of boost. If its in the budget, I'd seriously think about throwing on some headers before you swap pulleys. You may find that you'll reach your goal while sticking with a comparatively 'safer' setup.
You think I should installed the headers first? you mentioned 'safer setup' is that due to having the headers installed alone without upgrading to the 2.87 pulley? if so what kind of headers that is cost effective and doesn't exhibit a lot of heat should I invest in? Is ceramic header's good for heat dissipation?
Old Apr 13, 2011 | 03:16 AM
bigc's Avatar
Wings Nation
all things being equal, you should see lower intake temps and lower cylinder pressure with the 3.12 pulley than the 2.87. many on here run the 2.87 with no problems, just be aware that higher temps and more pressure put you at higher risk for detonation. headers are a good mod since, in general, they will allow you to make more power with less boost (lower intake temps, less cylinder pressure due to more free flowing exhaust).
Do what you want for headers - DC headers are a cost effective option (i'm saving up for Tomei headers though). ceramic coating, jet-hot coating, heat wrap - you're not dissipating heat, you're keeping it within the piping so you're not cooking all the stuff around the piping.
Old Apr 13, 2011 | 10:11 AM
show2nite's Avatar
BIGC! What you think about top speed headers?
Old Apr 13, 2011 | 12:36 PM
bigc's Avatar
Wings Nation
don't know anything about them
Old Apr 13, 2011 | 02:21 PM
idrivetsi's Avatar
2.87 is how much boost?
Old Apr 15, 2011 | 10:02 AM
show2nite's Avatar
Supposedly for 1 psi = 20 HP
Old Apr 15, 2011 | 10:59 AM
show2nite's Avatar
I'll be going forward with the 2.87 pulley setup, coming home baby >> 400WHP.
Old Apr 15, 2011 | 11:00 AM
show2nite's Avatar
Big C does the Engine damper have any noticeable benefit ??
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
n2fooz
Sep 4, 2015 07:46 PM
