G35 Fuel Flow Rate
Old Aug 1, 2004 | 10:02 PM
Hydrazine's Avatar
G35 Fuel Flow Rate
Any one know what the nominal and maximum fuel flow rate is for a N.A. G35? I need it for fuel line pressure drop calculations.
Any units of mass or volume would be glady accepted. Thanks!
Better is the enemy of good enough.
2004 G35 6MT Blk/Blk Sedan Stillen Air, Stillen Exhaust
Old Aug 1, 2004 | 11:12 PM
Q45tech's Avatar
Re: G35 Fuel Flow Rate
Read your grams per second of air flow [MAF with OBD2 scanner] and divide by 14.7 at idle and cruise and 12-10 at WOT correct for rpm. 222gms/11= 20 gms of fuel
Another way to look at it is 300 HP needs 150 pounds per hour of fuel [2.5 pounds per minute] ....2.5/6.2= 0.4 gallons per minute minimum.
On the Q45 278 HP but 307 lb/ft the fuel pump capacity is about 1 gallons per minute [255 lph].........so at least a 150% safety margin.
Old Aug 2, 2004 | 07:11 AM
Q45tech's Avatar
Rail high flow pressure wave dynamics are critical as resonances can occur when changing flow rates on system.
Returnless are 3 times more critical, external presssure wave dampers may be needed to avoid variations above 3% in pressure at injectors thru out open time.
Remember regulator is on the pump a long way from injectors.
http://www.mototron.com/prod_micrafueldamper_5bar.htm
Old Aug 2, 2004 | 03:17 PM
Hydrazine's Avatar
Awesome response Q45! That's the kind of engineering detail I was looking for.
Thanks!
Old Aug 2, 2004 | 04:10 PM
Q45tech's Avatar
Q45tech does not stand for Technican but "Technical" my Masters Degrees are in Electronics and Finance, not Automotive Engineering. But I read the right text books!
Old Aug 2, 2004 | 08:10 PM
qmaster8's Avatar
I heard you are a big expert when it comes to the Technosquare and the modifications it makes to the amount of fuel given to the engine. I am thinking about adding the crawford plenum and the high-flow cats and am trying to find out if I will need to get the Technosquare ECU upgrade to adjust for the changes to the required fuel to the engine. Do you think I need some kind of engine management or can the stock ECU relearn the new mods?
Thanks alot.
Jason
Old Aug 2, 2004 | 10:00 PM
Q45tech's Avatar
ODB2 allows a 20% variation in standard conditions before it throws a light.
Somewhere in the software is an absolute limit in grams per second which correlates with a MAF voltage number above which a code is thrown.
But minor mods [even cats and exhaust manifolds, plenum, etc] cannot raise the air flow more than maybe 10-12%.[surely not 15%] .
By leaning the mixture [technosquare ecu software] HP increases as hot weather octane safety margin decreases.
Old Aug 3, 2004 | 12:13 AM
Hydrazine's Avatar
Would that be "Tech" like Georgia Tech?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
ClwMike
Jul 23, 2015 12:55 PM
