car starts, idles and then turns off! Only turns on if u give it gas!
Old Aug 31, 2009 | 06:40 PM
saulg35's Avatar
Car only turns on without giving it gas when its cold. After heating up it only turns on if you hit the gas pedal. I never had this problem, it began after i disconnected the battery to add a sub to my bose system. After i plugged in the positive this problem started. I did th ECU reset and it didnt help. Thanks in advance for the help!
Old Aug 31, 2009 | 07:08 PM
jamisxc's Avatar
Same problem I had when I disconnected the battery to install a new one. I cleaned the throttle body and that fixed it some how. Till this day, I haven't able to get a clear answer on how cleaning the throttle body fixed the problem where the car was running fine before i disconnected and installed new battery.
Check out the link below:
https://g35driver.com/forums/engine-...-start-up.html
Old Aug 31, 2009 | 07:11 PM
dofu's Avatar
20 Year Member
Check the MAF sensor, and check for a vacuum leak. Unplug the neg on your battery for 10 min just to be sure you did reset the ECU
Old Aug 31, 2009 | 10:13 PM
MobbinTehG's Avatar
Hmm, I vote to try to reset the ECU, if this suddenly happened after the battery was changed then it would make sense that it could be a computer issue.
Also, its important to note that the battery was changed because it failed for one reason or another. Perhaps there is another electrical problem which caused the symptom of your battery failing. What I'm saying is that there is a chance that the battery was not the cause of the problem, but rather a symptom of another electrical system issue.
Old Aug 31, 2009 | 10:52 PM
JuniorBass's Avatar
I just unplugged my battery, cleaned the throttle body and replaced the air filter. Cars running like a charm now.
I was experiencing the RPM's dipping upon start up fofr a few months now. The car had died once on me but never agian.
Old Sep 1, 2009 | 11:00 PM
MobbinTehG's Avatar
Be VERY CAREFUL if you decide to clean your throttle body.
It says in the service manual that it isn't supposed to be cleaned. Also you MUST disconnect your battery before you do it. (I would suggest bleeding the power out of the system as well in order to make sure). If you don't take those steps you may have to take your G to the dealership for a costly reprogramming (~$300). As always, make sure to read up about it on g35driver before performing the cleaning.
Old Sep 2, 2009 | 04:57 AM
dofu's Avatar
20 Year Member
Could be just a very dirty air filter too...
OP: Do you still have warranty? If so, why not bring it in and let it be their problem?
Old Sep 6, 2009 | 01:05 PM
saulg35's Avatar
Hey guys i finally cleaned the MAF and the throttle body, then I disconnected the battery for 10 mins. I bought a MAF cleaner and throttle body cleaner from pepboys. I cleaned the throttle body from the outside i didnt take it out though:-s. But it worked!! thanks guys i appreciate the help!!
Old Sep 6, 2009 | 01:22 PM
WILLIE BEANS's Avatar
.. weird huh ...
chinee
Jun 10, 2024 07:48 PM
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
realtalk21
Jul 20, 2015 09:07 AM
