Twin SUPERCHARGED g35
Old 09-06-2009, 06:17 PM
parhamm1's Avatar
um....................... what?
  #32
Old 09-06-2009, 06:26 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
is your motor built? imho it doesn't make sense to run this w/o the slightest build of the motor because your going to boost like a mother when the vortech gets going.. i mean props for the build but be safe.. have fun tuning that thing
edit what injectors are you going to run?
  #33
GreenGoblin's Avatar
The goblin resurrection
pending fail after first full boost pull.
  #34
Old 09-06-2009, 06:27 PM
Really Needs a Life
haha vroooom *BOOM* lol
  #35
Old 09-06-2009, 06:34 PM
g35&cd6's Avatar
stock everything im just gunna use a wastegate to regulate boost cant afford any internals
  #36
Old 09-06-2009, 06:38 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
Your first full power dyno pull:
  #37
Really Needs a Life
^sounds like a recipe for success right there
  #38
Old 09-06-2009, 06:42 PM
JOKER's Avatar
CLUB MODERATOR
what the hell?
Why did you get two SC then?
Should have gotten some internals before putting massive amount of boost into the engine.
You put two SC and then gonna regulate the boost with a westegate...........basically draining all the boost from one SC cuz you only gonna need one?
Logic is not your friend.
Might wanna wear a bomb suit when you start that thing up
  #39
Old 09-06-2009, 06:47 PM
j 4 lD's Avatar
It looks like there's a turbo in the lower right hand corner of the engine bay..
Where is the other SC?
  #40
Old 09-06-2009, 06:50 PM
JOKER's Avatar
CLUB MODERATOR
that's a SC
  #41
Old 09-06-2009, 06:57 PM
g35&cd6's Avatar
haha yall guys are funny yea its a waste...as of now...im just banking on low boost now to get heads turned and maby some help with internals later its been boosted for about 10K miles and runs ok i just got a good deal on the roots so i couldnt pass it up. only took me a day or to to modify both kits to fit everything
  #42
Old 09-06-2009, 07:40 PM
seymore4's Avatar
This thread is awesome LOL
  #43
Old 09-06-2009, 07:51 PM
Really Needs a Life
i dont know which post is worse.
j 4 lD It looks like there's a turbo in the lower right hand corner of the engine bay..
g35&cd6 haha yall guys are funny yea its a waste...as of now...im just banking on low boost now to get heads turned and maby some help with internals later its been boosted for about 10K miles and runs ok i just got a good deal on the roots so i couldnt pass it up. only took me a day or to to modify both kits to fit everything
^your going to bank on low boost? who are you going to for the tuning?
btw you have failed to mention what injectors your running for this "head turning" setup? also, what EMS are you going to run? are you running an oem fuel pump too?
  #44
Old 09-06-2009, 08:04 PM
V35 Skyline GT's Avatar
6MT Coupe
There's a first for everything.
G/L
(Kaboooom)
  #45
Old 09-06-2009, 08:18 PM
j 4 lD's Avatar
uh.. was my question not legit?
Quick Reply: Twin SUPERCHARGED g35
