service engine soon
Old Aug 21, 2004 | 11:20 AM
madabs's Avatar
service engine soon
i put in my grounding wires on and when i started the car the ses light came on any suggestions. i also checked to see that i put the grounds in the correct places and that all the plugs are in. thanx
03.5 k&n air filter with custom z tube
ur crank pully ab enitz 18x8.5 type 5
Old Aug 21, 2004 | 11:48 AM
CKwik's Avatar
Re: service engine soon
I am not sure you can do this with newer Nissans/Infinitis but on older ones you could pull the MIL codes from the ECU. This would tell you what system is causing the code. And OBDII Scanner would be easier and quicker, but they are rather pricey($150 for the cheapest that I've seen).
Old Aug 21, 2004 | 03:13 PM
Msedanman's Avatar
O.F. Administrator
Madabs,
First I've heard of a CEL due to installing a grounding kit.
The 2 are not likely related, but it is possible that you left a hose off, or a harness disconnected somewhere????? Check for something amiss, then do a pedal method of the basic ECU reset found HERE.
If you've done nothing wrong with the Grounding Kit install, and find no disconnected wires or hoses, then the reset should take care of the CEL.----
If the CEL comes back, you'll need to scan the computer for a code to know where the problem lies.
C.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Aug 21, 2004 | 09:19 PM
Catatafish's Avatar
Go to Auto Zone and they'll tell you what the error code is for free.
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
