Codes: p0014 & p0078...help!!!
Old Dec 10, 2009 | 03:42 PM
BoThai's Avatar
Hey everyone, couple weeks ago, while driving, my serpentine belt broke, which I have replace. When I took her out for a spin, my car turn off. Everything electric works just fine. The problem now that I'am having is the Service Engine Soon came on, & my idle goes down less than 1k & while driving sometimes the engine turns off while I'am at a complete stop. I had a friend look at it, & run it through the computer. It gave me 2 codes: p0014 & p0078. My friend advised me that I had to replace the "camshaft adjust valve" bank 1, which I did. But the symtoms are still the same! Anyone experience this before or know what I should do next?
Old Dec 13, 2009 | 02:19 AM
bythabay's Avatar
sounds to me like the broken belt & pieces hit a sensor or two and threw something out of whack... I would test all the sensors and replace as needed. Next time try replacing the belts on schedule to avoid this scenario. I actually had a car a few weeks ago that was a complete nightmare. I was just supposed to do the rear brakes, but instead I had to saw away at a seized caliper bolt (had to remove caliper), replace a wheel stud, and to top it off when I starter it up after that stuff was done, the power steering belt shredded to bits (it was done for).
Old Jul 1, 2013 | 01:06 PM
carl576's Avatar
The same issue just happened to me, belt broke and all. Can you tell me what was the end result and whats parts were replaced.
Old Jul 1, 2013 | 01:21 PM
bythabay's Avatar
In my case I just had to replace the broken parts. No sensor damage was done.
Old Jul 1, 2013 | 05:44 PM
carl576's Avatar
Can you tell which parts you replaced and much it set you back?
Old Jul 3, 2013 | 12:03 AM
bythabay's Avatar
Two drive belts, around $30 total for parts.
puga
Mar 27, 2016 05:04 AM
invincible514
V36 Engine, Exhaust, Drivetrain & FI
Sep 15, 2015 05:06 PM
G35-31
Jul 1, 2013 01:47 PM
freakta
Dec 3, 2010 08:18 AM
