Leaking valve cover write in campaign
Old Jun 9, 2010 | 09:56 AM
  #61
OKStateG35's Avatar
Originally Posted by WINTERDEVILG35
lol....what some people should know is that even when you change out your rings (which you should do if you do have a leak in the spark plug hole) is that the new ones are just going to go out as well (depending on the severity of the situation).
what happens is the positive crankcase ventilation system isn't working properly. So when there is an issue with the system then it sucks oil up from the VC into the intake manifold which then gets sucked into the combustion chamber to be ignited and blown out the exhaust. But when oil starts to accumulate at the top of the VC (on the inside at the top where the rings are) because of inproper PCV it will eventually eat away at the O-rings and causing a leak into the sparkplug hole, which then can also lead to misfire due to a damaged coilpack. High heat mixed with oil and rubber/plastic (O-rings and coilpacks) is a bad combination.
It could be bad PCV hoses (cracked, deteriorated, ect.) and/or it could be a blockage in the hoses. What you need to do when you do get new o-rings or VC is service your PCV hoses. Ensure they are in good condition, flush them of all excess oil, and check/clean the PCV valve. Or else the new O rings or VC or coilpacks are just going to go bad on you again in time. Fix it at the root of the problem first then work up.
So would a catch can help solve the problem or is that a completely different issue?
Old Jul 14, 2010 | 01:51 AM
  #62
alexpsc's Avatar
Originally Posted by R&D Factory
second test vehicle took in today using our o-ring kit on a g35 coupe with appox. 94k miles. o-ring replacement was performed and will be checking the car at 3k and 5k miles.....
are you guys still selling the kits at the same price
Old Oct 4, 2010 | 12:15 PM
  #63
R&D Factory's Avatar
thank you for waitting after few on-road testing the O-RING replacement is up for sale now, please pm us for more infor ,thank you .
Old Oct 4, 2010 | 12:57 PM
  #64
Blue Dream's Avatar
I drove ttrank's car solo
Now that's good news!!
Old Oct 4, 2010 | 01:39 PM
  #65
OCG35's Avatar
is it just the o-rings? Or an entirely new type of cover with replaceable o-rings?
How many miles on test cars? And are they anyone on this forum?
Old Oct 11, 2010 | 02:10 PM
  #66
thescreensavers's Avatar
Mr.202?
hmm interesting.
Old Oct 11, 2010 | 02:46 PM
  #67
OKStateG35's Avatar
Definitely interesting. I would like to know more details regarding test results and what all comes with the kit.
Old Oct 12, 2010 | 04:19 PM
  #68
saywat?'s Avatar
subd! its about freaking time lol
Old Oct 20, 2010 | 01:20 PM
  #69
eyeSea's Avatar
so, is this an entire valve cover or a o-ring we can use?
Old Nov 5, 2010 | 06:37 AM
  #70
is only the O-ring gasket no valve cover the picture is just to show you where the O-ring go's, you can buy the O-ring gasket or you can come into R&D we can replace the O-rings .
Old Dec 23, 2010 | 05:22 AM
  #71
still going
Old Jan 13, 2011 | 08:18 PM
  #72
to the top
Old Jan 13, 2011 | 08:21 PM
  #73
saywat?'s Avatar
so we can use the same valve cover? diy or some kind of instructions please
Old Jan 13, 2011 | 10:35 PM
  #74
04G35NYC's Avatar
so wait, the whole problem with this was just the stupid Rings... how much are the rings shipped to 11209?
Old Jan 18, 2011 | 03:02 AM
  #75
medianjoe's Avatar
Very interested. I need this seal now !!!
