Engine squeaks on cold start ups
Old Mar 14, 2010 | 10:34 PM
GBALLA's Avatar
As the title says, I hear a squeak from the engine bay area on cold start ups.
I'm not sure if it is the belts. I have replaced the oil and filter just recently.
I do have a coupe middy installed but thats it for exhaust components.
Any suggestions on how to fix the squeak? Thanks in advance!
Old Mar 14, 2010 | 11:02 PM
xxkylexx's Avatar
mine did this on cold startups as well a month or so back. replaced both belts and it solved the issue.
Old Mar 15, 2010 | 07:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
If that car was driven even 10,000 miles/year it would have ~50K. I can see the belts being gone by then.
OP look at your belts and look for cracking or missing nibs. I would recommend replacing with OEM belts and DIY. Will cost you $40 and take less than an hour.
Old Mar 15, 2010 | 11:15 PM
GBALLA's Avatar
Thank you guys for the input.
I'll be replacing the belts soon with the diy video!
Old Mar 15, 2010 | 11:50 PM
mugen_rsx09's Avatar
My engine also starts squealing at cold start ups, but i had my belts replaced among with UR pullies a month ago
Old Mar 27, 2010 | 12:41 AM
midnightrunner's Avatar
Have the same problem with squealing on cold starts...so annoying, but yea its the belts, you should look into tightening up a little, to see if that helps
Old Mar 27, 2010 | 05:58 PM
G35nNJ's Avatar
My belt started squealing 2 weeks ago after we had heavy rain for days here in NJ. After tightening the belt it stopped for awhile then started back again as soon as it rained again. I'm gonna tighten it up one last time before I replace them. Without a belt tension gauge how can you tell when it's tight enough (don't want to over tighten it )
Old Mar 28, 2010 | 10:02 AM
F1fanatic's Avatar
Be careful not to over-tighten belts. When I replaced my belts I replaced the bearings as well. Only about a $35 add to the bill and an extra measure to ensure I addressed the squeaking problem.
snic09
Nov 8, 2017 01:46 PM
andyg35c1
Aug 29, 2015 03:37 PM
wuppiedog
Aug 7, 2015 11:16 AM
restrada
Aug 6, 2015 01:44 PM
ddietz97
Jul 26, 2015 06:16 PM
