Do I need to change my oil after seafoam or lucas only in fuel? Also Seafoam VS Lucas
Old Jul 16, 2014 | 01:35 PM
PLENUMCOUPE's Avatar
Bump For my last post
Old Aug 27, 2014 | 07:52 AM
jake_'s Avatar
Redline SL-1... This stuff talks the talk and walks the walk...
Old Aug 27, 2014 | 09:25 AM
Urbanengineer's Avatar
Redline for fuel and sea foam for cleaner engines.
Old Aug 27, 2014 | 10:31 AM
I ended up using seafoam for the fuel
Old Aug 27, 2014 | 10:54 AM
gary c's Avatar
Originally Posted by i3eezenotch
I found out the local pep boys has the redline stuff. So I'm gonna go get that in 5 min. I am nearly on empty so I was gonna dump it in my tank right after getting it, then filling up on the way home. Tomorrow I have a 3-3.5 hr trip I have to make. Is it OK for it to sit in my tank for 20 or so hours before I go on this long trip? And just to re-confirm (sorry I just want to be sure I'm not making anything worse)...I can use redline SI-1 and not change the oil?
No, it's not OK to leave RedLines injector cleaner in a near empty tank for any length of time! This stuff cleans very well and might clean the krud from the bottom of your gas tank and load up your injecters. Half a tank is safe but nothing less...I speak from experience!
Gary
Old Aug 27, 2014 | 11:26 AM
JOKER's Avatar
CLUB MODERATOR
I would not clean anything at 30+k
Your engine should not be clogged up with anything at that kind of millage (unless you used some really nasty fuel that you mopped off the floor)
I would blame fluids on your poor gas millage.
Invest in to good quality fluids through out the entire vehicle and enjoy good millage.
New quality engine oil
Good synthetic gear oil for the diff
Old Aug 27, 2014 | 11:35 AM
JOKER's Avatar
CLUB MODERATOR
Thread revive here. Can anyone who's tried these products- redline, gumout, zmax, Seafoam, Berryman, bg44, Lucas - tell me which is the best value?
My opinion is that you are not going to see a major difference between those products.
They will all do the job with a similarly equal results. Each brand uses all kinds of marketing tactics to gain more market traction than it's competitor. At the end of the day that's just what they are, "Marketing tactics". All products will deliver and equal results IMO and clean your engine sufficiently.
Use of majority of those products is redundant anyways.
I have 170k on my G and I only used Seafoam once at 100k. No difference was noted after seafoam use. I'm still getting 21/25 mpg before and after the seafoam.
As I've mentioned before, IMO your main millage culprit are the fluids and moving parts.
So pay attention to everything that rolls and has any kind of friction after the engine. Lubricate and maintain those parts properly in order to reduce the friction.
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
JoeMac
Aug 20, 2015 10:17 AM
