Help: P0335 from hell - what can it be?
Old Aug 27, 2014 | 11:59 AM
UR2EZ's Avatar
Update: realized the real problem is I replaced both cam sensors and knock sensor, not the crank sensor, so I paid the stupid-tax which so far has come to 225+80+80=385 and about to be 465 on these damn oem sensors. At first I thought the initial fix had been botched by the ebay sensors I purchased for $16 each, so add another 32 for my stupid-tax.
Nissan 23731-AL60C, Engine Crankshaft Position Sensor $80 on Amazon and prime eligible.
by Nissan
Link: http://amzn.com/B00BFE1V80
Cam sensor Driver - AL61A
Cam sensor Pass - 6J90B
Crank sensor - AL60C
Knock sensor - 2A000
P0335, car stalls after driving about 10 miles only when outside temp is above 90.
Replaced both sensors, problem persisted
replaced both with new oem, problem persisted
replaced knock sensor and harness, problem persists
I will be taking to a mechanic next, and based on my research it could be any of the following:
-loose/stretched timing chain
-bad harness wires to the sensor
-rusted/bent crankshaft or flywheel
-corrosion near bottom of battery cable (i had corrosion pretty bad a year ago and chopped to place a new terminal, but the corrosion could be deeper)
What else could cause this? I have heard dirty oil, but that's def not it. Can a clogged fuel filter cause this code? I have never changed it and i'm at 130k
Old Aug 27, 2014 | 12:15 PM
coffeysm's Avatar
Originally Posted by UR2EZ
If anyone has any further suggestions, I would appreciate it.
P0335, car gets hot and then stalls after driving a bit.
Isn't that the crankshaft sensor?
Old Aug 27, 2014 | 12:24 PM
UR2EZ's Avatar
yes sir it is the crank sensor position a circuit. I replaced both with aftermarket then all three (cam,crank,knock) with oem when it didn't fix.
Old Aug 27, 2014 | 01:20 PM
Jeff92se's Avatar
Red Card Crew
If it's getting hot, are the fans turning on? Have you checked both water temp sensors? (if there are two) Usually one for the guage and another that the ECU uses for timing etc...
Old Aug 27, 2014 | 01:49 PM
UR2EZ's Avatar
Sorry, I meant the stalling only occurs after the car has driven about 10 miles and the ambient outside temp is above 90. The engine temp is stable and the fan is still coming on. I didn't mean to sound like an overheating issue.... updated op
Old Aug 27, 2014 | 04:20 PM
coffeysm's Avatar
You replaced the crankshaft sensor though right? The one underneath the car?
Old Aug 27, 2014 | 04:52 PM
UR2EZ's Avatar
Dear lord - I have spent so many hours researching this issue, and I have a degree in research...
I have just now learned about the 4th sensor (top>down)
So for any future visitors here, I will post what would have helped me so long ago...
Part numbers:
Cam sensors -
Driver side - AL61A
Passenger side - 6J90B
Knock Sensor - 2A000
Good gawd hopefully this nighmare is soon over
Old Aug 27, 2014 | 05:21 PM
coffeysm's Avatar
I replaced the two (cam and crank) facing the firewall. I was able to reach behind without removing anything....
Are you saying there is a sensor truly 'under' the car? I have replaced 3 sensors and I thought the trio was it....
Yea, the two you replaced are BOTH cam sensors. There is only one crank sensor on the bottom of the car.
Attached Thumbnails Help: P0335 from hell - what can it be?-128762642.gif
Old Aug 27, 2014 | 05:27 PM
UR2EZ's Avatar
Thanks guys, this has really been helpful and somehow the information seemed elusive until now, all of a sudden I find multiple threads with the info I needed. I guess my search terms were slightly off... There are so many incomplete forum entries out there where people identify their problem and never report back with their solution.
Thanks again!
Old Aug 28, 2014 | 06:27 AM
Frankieg35's Avatar
Originally Posted by Ur_girls_lover
I'm sorry for doing this I'm new and idk how to create a thread but can anyone tell me if I should go the cheap route an get raceland coilovers or spend extra and get BC racing coilovers plz help
You get what you pay for, get BC..
Old Aug 28, 2014 | 08:18 AM
Lartytiejdke3's Avatar
Wtf a coilover question in this thread?
Alrighty
11bEMT
May 27, 2022 03:13 PM
06g35
Feb 14, 2022 05:59 AM
Frostbite91
Aug 20, 2015 07:20 PM
