car died and wont start again?
Old Apr 21, 2010 | 10:15 PM
  #46
Bauer418's Avatar
Sounds good. Best of luck, keep us all updated. I'm sure it's something small though.
Old Apr 24, 2010 | 08:48 AM
  #47
badnblk's Avatar
fixed
i decided to stop messin around so i got it flatbedded to my mechanic. turns out the original problem was the cam positioning sensors but when they went down they popped 2 fuses in the IPDM which i didnt even know existed, changed those 2 fuses and car started right up no lights on dash nothin, im so pissed it was just fuses after. so for anyone whose sensors go down check your fuses in the IPDM located behind the battery under the wiper cowl
Thanks for the help Bauer much appreciated
Old Apr 24, 2010 | 12:41 PM
  #48
Bauer418's Avatar
Glad to hear you had the problem solved all along! Fuses can be a pain, especially with where they put the 3rd fuse box on the Gs. Anyway, glad you got it all sorted out. Enjoy the G.
Old Aug 27, 2018 | 10:26 AM
  #49
Kingrebel's Avatar
G35 stall while driving, won’t start, crank.
I have the the same problem replaced both cam and crankshaft drove it home, got stuck a block away from home. First it would crank for long periods until the car looses power, then it’s not cranking at all and wouldn’t start.
do you remember which fuses the guy changed?
Old Aug 27, 2018 | 08:32 PM
  #50
Blue Dream's Avatar
I drove ttrank's car solo
^Did you use OEM sensors? If not I'd bet that's your issue. A ton of our cars don't play nice with aftermarket electronics including sensors.
Old Aug 29, 2018 | 10:27 AM
  #51
Kingrebel's Avatar
Yes i used oem sensors replaced it myself because i literally had no choice. Drove it home that day, the next day drove it for like 7 miles, it died on the street, it cranks but no start, eventually it stopped cranking. Is it the fuselike mentioned above? If so which one is it so that i can purchase one? Or does it need a tune up? The fact is the car wont start or move so i might have to do all of this myself seeing that im broke atm and start a new job today.
Old Dec 17, 2021 | 05:07 PM
  #52
april santos's Avatar
04 infinti g35 coupe
I have 04 infiniti g35 coupe and my battery keep draining out and its brand new the alternator is also brand new what can be causing this
Old Dec 18, 2021 | 05:34 AM
  #53
Scorpi0's Avatar
Could be many things. U can use a multimeter to look for current draw while u pull out fuses one at a time and see which fuse stops the current draw.
Old Dec 19, 2021 | 12:54 PM
  #54
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Car should be pushing 14.5 volts with the engine running, 12.5 with the engine not running.
One fairly common issue is for the radio head unit to fail and start parasitically drawing power with the engine off. Use a multimeter and amp draw test to see how much power is being consumed with the engine off.
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
newg37
Jul 26, 2015 09:32 AM
kenthung
Jul 21, 2015 05:56 AM
