Getting a new block/ new car
Old Jun 8, 2010 | 04:30 PM
o3 g35's Avatar
ok, so about a month ago i figured out that i was 8000 miles over my last scheduled oil change and i started to hear a noise from the front of my engine. i went and got my oil changed, but figured out that I almost threw the front rod, which explains the noise. about a week ago the noise got way worse and the car is parked in my drive way. i am wondering if i should get a whole new block with better internals ready to go for a turbo? or just sell it and get a new different type of car?
Old Jun 8, 2010 | 04:32 PM
YeloFva's Avatar
Damn! 8000 miles over!?!? How did that happen?
Old Jun 8, 2010 | 04:36 PM
o3 g35's Avatar
Unhappy
i didnt pay attention to when i was suppose to get it done, i learned from my lesson now i have to get a new block or car
Old Jun 8, 2010 | 04:39 PM
Eric@TCGMiami's Avatar
www.car-part.com
You can get a stock block and just swap it in drive away
OR
Find a vendor here that can get you pistons, rods send your block out to the machine shop and have them put the engine together. (first find out if you need to bore the engine over and if you need thicker bearings.
Old Jun 8, 2010 | 04:41 PM
o3 g35's Avatar
i already have a shop that can do it, they were just going to get a new block and put better internals in it
Old Jun 9, 2010 | 04:38 AM
jonnylaw's Avatar
Did you go 8k over the ~3k recommended change-for a total of ~11k w/out oil change, or 8k since last oil change? How do you know that your engine is done besides hearing a noise? Does the car run? Is it really weak on power? Are you throwing any codes (cels)?
Maybe you were running really low on oil. Do you check your oil levels regularly?
If you upgrade to lower compression built engine for turbo, just know you will be making less power than stock while you are N/A b/c of the lower compression.
Have diagnostics done on the car by a professional before buying/building a new/used block to be sure your engine is really toast before you shell out $$$.
Old Jun 9, 2010 | 04:41 AM
HenryLee's Avatar
^ +1. 8k over 3k or 8k since your last oil change? Well if you were on synthetic oil, I think you would have been okie. But for regular dino oil 11k is a lot!
Old Jun 9, 2010 | 10:02 PM
o3 g35's Avatar
i was around 11k over. and i have loss in power the fastest my car will go is around 50 miles an hour. it wont go any faster. and plus every time i push in the clutch my engine cuts its self off
Old Jun 12, 2010 | 12:47 PM
fluffykurt's Avatar
Z06 and call it a day.
Old Jun 12, 2010 | 01:57 PM
G35xTurbo's Avatar
Originally Posted by fluffykurt
z06 and call it a day.
lol
Old Jun 12, 2010 | 02:37 PM
Tollboothwilley's Avatar
You were probably not only running on terribly broken down oil, but also very very low on oil.
I would do a compression test...but I'm sure you've trashed the motor.
Old Jun 12, 2010 | 03:20 PM
jamesond19's Avatar
gotengines.com, great site with awesome prices/warranty/availability.
Old Jun 12, 2010 | 10:43 PM
youngG's Avatar
wow how u forgot to change dont have the feelin like it been a while let me just change it
keep it as project car
Old Jun 13, 2010 | 01:28 AM
^^ is that supposed to be Engrish?
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
