Do I have a VLSD or not??? 04 5AT
Old Aug 2, 2010 | 02:10 PM
Tollboothwilley's Avatar
Only one way to really test that - Jack the car off the ground and count the revolutions. 1 Tire revolution should be 3.3 OR 3.5 input shaft revs depending on the FD.
Old Aug 2, 2010 | 02:15 PM
herrschaft's Avatar
^I still have the original diff laying around, I'll see if I can do that later.
Originally Posted by MikeGrote
yes, fd i think in all 06 coupes is 3.5:1. however, i believe in 04, the autos had 3.3 gears and the manuals had the 3.5 gears
Not one department at the dealership could give me an answer. I was under the impression I had the 3.3 gears. Can you give me a link to where you found that information on the Infiniti site, was looking earlier but couldn't find anything.
Old Aug 2, 2010 | 02:25 PM
you could count the teeth on the pinion and ring and then do some simple math. That will tell you as well, but requires removing the gearing.
here is a link for the SPECS on 2005 coupes
http://infinitihelp.com/models/2005/...ifications.htm
Old Aug 2, 2010 | 02:36 PM
herrschaft's Avatar
^Thanks
Ok, so I've concluded my car being an 06 did have a 3.5fd.
Old Aug 3, 2010 | 08:30 PM
Yoshimura's Avatar
According to infinitihelp.com, 'Performance Tire & Wheel Package' for 03/04 includes: LSD, 18-inch wheels and titanium-finished center console.
Again, according to the same source, 03-05 5AT has 3.3FD. 3.5FD otherwise.
http://infinitihelp.com/models/2004/...ifications.htm
Old Aug 4, 2010 | 12:18 PM
pythonjosh's Avatar
I just had to replace my rear tires because one of them had radials exposed.
Tells me how good the VLSD is. Best way to describe it is:
It's not an "LSD", and it's not "not an LSD".
There's no saying "Boy I'm so glad I have an LSD" with the VLSD. Always best to go aftermarket, whether you have the VLSD or not.
Old Aug 5, 2010 | 10:27 AM
speedjunkie_G35's Avatar
Am I able to put a aftermarket LSD in my non vlsd pumpkin?
Old Aug 5, 2010 | 11:11 AM
pythonjosh's Avatar
Oh hell yes
Old Aug 5, 2010 | 11:55 AM
MikeGrote's Avatar
lincoln locker or spool...
Old Aug 5, 2010 | 05:48 PM
Sylvan lake V35's Avatar
Quaife or Cusco make them for our cars, with the base I think you need change out the stub shafts or some additional modifaction a quick search should give you the answers you need.
Old Aug 5, 2010 | 06:41 PM
MikeGrote's Avatar
^you talking to me?
MrIP35
Oct 25, 2015 11:13 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
