disconnecting ac belt????
Old Aug 11, 2010 | 06:53 PM
jon121587@yahoo's Avatar
Yea i was wondering if there are any gains from taking the AC belt off. The reason is because my dam ac belt keeps sqeaking and i have tried everything possible for it to stop and i t wont. I tried tightning and loosen it tried spary **** on it and still. Could it be my UR pulleys maybe?? Id rather have gains then a sqeaky ac belt haha
Old Aug 11, 2010 | 08:11 PM
Neu Era's Avatar
Just relieves stress off of the crank. Might as well take your A/C compressor out with it, those suckers are heavy.
Old Aug 11, 2010 | 09:46 PM
Yea i kno they are pretty heavy but i bet it hard to take it out lol
Old Aug 13, 2010 | 01:20 PM
surma884's Avatar
Try a new belt? Is the current belt OEM?
Old Aug 14, 2010 | 08:51 PM
Its not an oem belt its a belt for Unorthodox pullies. And the belt is brand new
Old Aug 14, 2010 | 10:30 PM
Tollboothwilley's Avatar
You need to adjust the tension of the belt. The belt is squeaking because it is too loose. Tighten the belt up and the noise will go away.
Old Aug 15, 2010 | 01:29 PM
Infiniti Chica's Avatar
My 1st step was to spray it with belt cleaner and once that didn't work (it rarely does I think), I had the engine steam cleaned, which the shop did gratis b/c I had been there for all of my repairs and inspections. Your cost might be $10-20. That worked! One thing to think about is that belt dressings to stop squeals usually become dirt and grime magnets, which ultimately fry your belt quicker.
If you tighten the belt until it stops squealing and it was greasy, you may over-tighten it, which is not good for the pulley and AC unit bearings. If that fails I'd get a new belt (OEM), inspect the pulley alignment, and bearings, and make sure the new belt is tightened correctly. If you change belts, be sure to thoroughly clean the pulleys before you put on the new belt.
Old Aug 15, 2010 | 03:43 PM
thanks for the help every body will prob try the steam cleaning process seems like that would work.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
happydays888888
Oct 6, 2015 06:04 PM
Blindside360
Sep 18, 2015 09:00 PM
