Check engine soon....?
Old Oct 29, 2010 | 11:25 PM
gary c's Avatar
I've been a member here for 5 years and have seen this question dozens of times but doing a SEARCH like I tell the NOOBS I found nothing after reading no less than 10 pages....CHECK ENGINE SOON warning how do I shut this off? Battery disconnect?
Gary
Old Oct 29, 2010 | 11:53 PM
bigc's Avatar
Wings Nation
battery disconnect is the easiest way. the pedal method doesn't always get rid of SES lights. be sure to pump the brake pedal after you disconnect the battery.
Old Oct 30, 2010 | 01:15 AM
gary c's Avatar
Thanks Chris, hopefully this will still be available the next time someone else has this issue.... Sorry I missed you at Long Beach, it was impossible for me to be there.
Gary
Old Nov 1, 2010 | 06:57 PM
gary c's Avatar
There's one more item everyone should be aware of after removing the negative side of the battery for any length of time other than the clock and radio stations need to be reset your G35 won't idle or run 100% for a few miles/days while the your computer relearns everything. Cold idle is low, just below 1K RPMS and SLICK failed to idle at restart a few times. No worries on the third day she was perfect once more....
Gary
Old Nov 5, 2010 | 08:16 PM
KingCobra's Avatar
Any reason why you chose to delete your check engine light? Did you know why it went off at first?
Old Nov 16, 2010 | 06:01 PM
gary c's Avatar
Once I saw the code I went over everything I knew of, fluid levels etc. Plus, she was running perfectly not a miss or hick up. My mistake was leaving the battery with the negative side removed for too long which ended being 8 to 10 hours. I had to reset the idle part of the ECU. Next time I get this code I'll run it by my buddy at Nissan then at least I'll know why the Check Engine Soon code was thrown.
Gary
Old Nov 16, 2010 | 10:47 PM
the_sedan's Avatar
gotta perform the idle air volume learn and throttle closed position when you do that.....thats why it wouldnt run good.
Old Nov 17, 2010 | 01:11 AM
Tollboothwilley's Avatar
Pedal reset ALWAYS gets rid of the SES light for me. Hard to get it right sometimes though.
Old Nov 17, 2010 | 01:21 AM
bigc's Avatar
Wings Nation
do you throw codes for running too rich?
Old Nov 17, 2010 | 01:26 AM
Calvin's Avatar
Overglorified Altima
Pedal method is the fastest, not always the easiest. Took me 3 or 4 tries.
Old Nov 17, 2010 | 01:41 AM
iiiiiekoiiiii's Avatar
fastest method is the gas pedal ecu reset.
take good 45 seconds...
Old Nov 17, 2010 | 09:08 PM
yup
You need to check the reason for the CEL. If you throw a code again make sure to find out what it is. I never reset it unless i know what code it threw.
Old Nov 17, 2010 | 09:17 PM
bigc's Avatar
Wings Nation
Kng0fHrts
Sep 15, 2015 05:40 PM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
