My G throws alot of smoke from the exausht and laggs to turn on HELP!!
Old Nov 4, 2010 | 05:23 PM
g35_charly's Avatar
my g35 all of a sudden turns off at times and shakes and throws smoke form the exausht...help what do yu guys thinnk it neeeds?...my service engine light lights on at times aswell
Old Nov 4, 2010 | 05:40 PM
petro2342's Avatar
It could almost be anything, but first thing comes to mind would be spark plugs. How much mileage is on your car and what year is it (not that it really matters, but helpful). Did you buy it used from a private party or from a dealership? Nissan did have a recall of their ignition relay stalling the car, but I kinda highly doubt that. Give us more info about your car and we'll progress from there.
Old Nov 4, 2010 | 07:24 PM
g35_charly's Avatar
i bought the car in lik around april wiht the millage of 90k...nd now it lik in about 102xxxx..its an 04 i got it used and havent changed spark plugs ever since juss oil changes...yu think it can b the spark pluggs?...thnxxx for your help
Old Nov 4, 2010 | 07:36 PM
pythonjosh's Avatar
Could be anything. Blown head gasket, oil leaking into the cylinders, or anything else.
Needs to go to an engine mechanic, or a gearhead friend.
Old Nov 4, 2010 | 08:01 PM
g35_charly's Avatar
yea now alot of smoke comes out off the exaust could be the head gasket...
you going to the meet today josh?
Old Nov 4, 2010 | 08:06 PM
Canadian's Avatar
Canada, eh?
What color is the smoke???
Old Nov 4, 2010 | 08:21 PM
g35_charly's Avatar
the color of the smoke is grey bro
Old Nov 4, 2010 | 08:45 PM
HangUp n' Drive's Avatar
Pull the codes. Excess fuel is black, dark gray. Oil is blueish. Antifreeze is white smoke. Keep in mind you can have combination's of the general colors. Seeing that it is time to change plugs go ahead and change them, the condition/deposits on the plug can also give insight into the running conditions of the motor.
Old Nov 4, 2010 | 08:53 PM
g35_charly's Avatar
so out of evrything i can do to it u think i should start by changin the spark plugs first?
Old Nov 4, 2010 | 10:40 PM
Nismo G's Avatar
If the smoke is grey/white? It can be water getting in the engine...driven in any storms lately?
Old Nov 5, 2010 | 12:05 AM
g35_charly's Avatar
nahh not lik in 3 weeks..but its throwin alot of grey/white smoke...but the car still runs
Old Nov 5, 2010 | 11:19 AM
pythonjosh's Avatar
Could also be coolant leaking into the cylinders. Could be any number of things.
Usually when a fluid is leaking into the cylinders, you blew a gasket.
Main gasket to check is the intake gasket, under the lower plenum.
But usually when you buy gaskets, it's a whole set.
Look all around your engine for anything visible on the outside of it. Look for leaks of anything, especially around the gaskets.
I'm always at the 190th and Anza meet thursday nights.
Old Nov 5, 2010 | 02:00 PM
petro2342's Avatar
Start by changing the spark plugs and go from there. Most likely they weren't changed so that's what I would do before jumping to the conclusion.
Kelvin Style006
May 23, 2016 03:47 AM
Vqalexisz
Oct 14, 2015 12:48 AM
wuzz-upp
Oct 3, 2015 04:21 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
n2fooz
Sep 4, 2015 07:46 PM
