Grounding points On Kinetix SSV
Old Nov 8, 2010 | 07:28 AM
jon121587@yahoo's Avatar
Hello was jus wondering if any body has a diagram or pictures of grounding points on the Kinetix SSV and reason for this is because jus purchased a grounding kit and could not find any pic or diagrams of a grounding kit installed with a SSV
Old Nov 8, 2010 | 08:18 AM
herrschaft's Avatar
You can ground it to any one of the bolts that mount it to the block. Grounding the plenum isn't necessary since it doesn't contain any electrical components. Just make sure the throttle body is grounded.
Old Nov 8, 2010 | 08:48 PM
From the Block to ????? Does the block mean to the timing chain area
Old Nov 9, 2010 | 02:34 AM
herrschaft's Avatar
Sure........that is the closest grounding point.
Old Nov 12, 2010 | 12:08 AM
the kit i purchased is a five wire setup so i need one wire from the negative terminal to the timming chain and the other four on the timing chain area too???? Can i get some specific areas where to connect cause im lost. thanks
Old Nov 12, 2010 | 12:10 AM
SxExCx's Avatar
I make a kit specifically for the SSV. PM me if you are interested.
Old Nov 12, 2010 | 06:27 PM
I was told by a mechanic that the engine was alunimun( how ever u spell it lol) so even trying to ground it to the timing chain area was not a good idea because it wont ground. He told me that the only place that i can ground it is on the kinetix manifold since its metal. Is this TRUE ??????
Old Nov 13, 2010 | 12:19 AM
herrschaft's Avatar
^That sounds like BS to me. I doubt our engines are different, but the blocks/engine on vehicles need to be grounded inorder to run. I just did a continuity check on a 3ft aluminum bracket and its conductive.
I could be wrong since I'm not a mechanic so lets see if others chime in.
Old Nov 13, 2010 | 12:40 AM
Shakuya88's Avatar
Aluminum is a metal. It does need to be grounded.
Old Nov 13, 2010 | 10:32 PM
so is there an incorrect way to installing grounding wires where its losing power on coductivity ??? reason why im asking is because the install instructions are for the regular plenums rather than the SSV
Old Nov 14, 2010 | 12:16 PM
Tollboothwilley's Avatar
Run away from this mechanic. Aluminum is METAL. It isn't magnetic, but it is metal and conducts electricity which is why it needs to be ground. On the 5AT the front 2 grounds you see on the timing chain are specifically for the transmission, FYI.
Old Nov 14, 2010 | 03:04 PM
Ok well Does Any body have install instructions for the Kinetix SSV. I have A five wire setup but dont kno where to install it ANY BODY PLEASE. Also I have searched every where it seems like but have had no luck.
Old Nov 15, 2010 | 01:33 AM
herrschaft's Avatar
If you have extra wires just hook them an any grounding point.
Old Nov 15, 2010 | 05:08 PM
To any grounding point meaning???? I have one wire hooked from the negative side on the battery to the timing chain area. With the other four wires would i connect to the same point on the timing chain to Where??? Im sorry for so much questions but it s because i want to do it right.
Old Nov 16, 2010 | 01:36 AM
herrschaft's Avatar
Your kit didn't come with instructions? There are multiple grounding points throughout the engine bay. I have SxExCx's kit installed but can't remember where every point was. Look for wires that connect to the metal panels that surround the engine, you could also follow the OEM grounding wires to see where they're at.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
