Switiching ECU's 2003-2003.5+
Old Nov 17, 2010 | 05:51 PM
Junkyardspecial's Avatar
Since I went FI I have had problems finding an ECU that will adapt to many of the aftermarket piggybacks or flashing devices. Ive decided that my best option is to swap ECUs out for a newer version g35 ecu. Now I can find a used ECU no problem for moderately cheap, I have having trouble finding the compatible harness and or any other parts I may need. has anyone done this before and if so what will I need?
Old Nov 17, 2010 | 07:01 PM
I was told by Osiris that if this is possible they would love a write up as this would bring them more customers. Anyone willing to help?
Old Nov 17, 2010 | 09:05 PM
Tollboothwilley's Avatar
I considered this many times. Not worth the cost and effort. ECU and wiring harness are different.
You are much better off just wiring up a piggy back. You'll save yourself time and lots of headaches. Not to mention money.
Old Nov 17, 2010 | 09:20 PM
In the previous PM I sent you I had mentioned about the greddy emanage if you knew if that wired into the old style ECUS just fine, or if it just looked for the normal wires every ECu has. I know it cant access closed loop functions but I really dont have a choice other than that and Haltech... and I dont have that money right now.
Old Nov 18, 2010 | 02:14 AM
Look at getting the Greddy Emamage Ultimate. Its a much better functioning unit for FI.
You can try the ECU swap, but my guess is that you'll spend a lot more money and tons of time on the swap. Maybe it will be easier than i suspect, but highly doubtful.
Another option is the UTEC and get the plug/play harness that the maxima guys created so it can be used.
Old Nov 18, 2010 | 10:30 AM
Canadian's Avatar
Canada, eh?
I don't see why it'd be difficult. I found an 04 harness for my car that I ended up not using for $200. Shouldn't cost more than ~$300 to do it. Would be well worth it just so you can have more tuning options.
Old Nov 18, 2010 | 11:11 AM
Its not an easy job swapping harnesses.
Old Nov 18, 2010 | 11:30 AM
Canadian's Avatar
Canada, eh?
It isn't incredibility hard, and it would be worth it.
Old Nov 18, 2010 | 12:43 PM
Im still waiting for returned calls to all the dealers and shops for assistance in this and slidegood has nothing . When I called shops to see if they could help, most of the time the guy on the phone had no idea what I was talking about.
Old Nov 18, 2010 | 09:52 PM
I found a harness, Bought the ECU and found a cheap Utec for sale which I will then upgrade to a haltech when I get the money. The guy selling the harness will also give me instructions, I may do a write up with photos on a DIY when I get it depending how much time I have and how cold it is outside haha.
Old Nov 22, 2010 | 01:12 AM
Cool. Do the write up for us
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
MThawkins86
Oct 24, 2015 02:07 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
