Turbonetics ST install!!
Old Dec 26, 2010 | 04:31 PM
  #136
Tollboothwilley's Avatar
if you are getting a SES light and the code pops up as TPS then find someone with a VQ35 with a running motor. Swap throttle bodies and if it starts up and runs you found your issue. It could be wiring, or a bad throttle body.
Old Dec 26, 2010 | 05:48 PM
  #137
DanielsG's Avatar
Ok. That's going to be a pain, I don't know that many people with the same car that would be willing for me to use parts if they're car...any one want to help in that's in s. Florida. My car is at Olympic Motorsports in margate.
Old Dec 26, 2010 | 06:53 PM
  #138
i'm sure there are plenty of people. You can find a TB for sale on the forum normally around $80. less if its local.
Old Dec 26, 2010 | 09:28 PM
  #139
DanielsG's Avatar
yeah. i cant find any on the forum right now. should the open loop fueling on the utech be on or off? i remembr we tried to scale the injectors and it didnt let us. i am wondering if that was the problem. the screen said that it was "for later use only" or something. and didnt allow us to adjust them.. any advice?
Old Dec 27, 2010 | 03:31 AM
  #140
woRthy's Avatar
sounds like a huge pain in the *** your having!!!
sounds like whoever sold you that kit ripped you off...
try going to junkyard for a throttle body
Old Dec 27, 2010 | 12:18 PM
  #141
there are guys parting out entire engines in the marketplace...they have TB's. I've seen them.
As for the UTEC, you need to read and re-read the installation manual located on the link i sent you. It has all the information and if your tuner is half decent he should understand what it does if he reads the manual.
OPEN-LOOP fueling is for highly recommended for FI guys. You will max out the MAF tuning options around 4.5 PSI. You need to use the MAP sensor.
Old Dec 27, 2010 | 12:48 PM
  #142
josh.irvine.6's Avatar
Correct me if I'm wrong, but I thought the MAF sensor was good for up to 7/8 psi of boost?
Old Dec 27, 2010 | 01:35 PM
  #143
DanielsG's Avatar
I have the map sensor. So the open loop should be on..,because it's not letting us scale injectors otherwse
Old Dec 27, 2010 | 04:21 PM
  #144
DanielsG's Avatar
Ok. It is the Tps. Now we have to get a new one.. On it's way.. And tune... I hope.
But, we need to bring to dealer for master reprogram??? Is there Ny way to do it our selves?
Old Dec 27, 2010 | 09:55 PM
  #145
DanielsG's Avatar
Ok. I replaced the Tps and te cr works now but when the utech is plugged in we do not have controll of the throttle. It just idles. We trod calibrating etc... Why is this so hard!
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
