Turbonetics ST install!!
#121
you dont need the code....you can do a hard reset on the UTEC which will set it back to factory specs and remove codes/maps that are on there already
http://turboxs.com/uploaded_images/553.pdf <<<--- This is the installation manual which has instructions on the reset
go to page 54
You are going to download the latest versions and FLASH them to the UTEC as if you were upgrading. It will over-write all the information and reset the UTEC so you can use it.
go to page 54
#126
its on the TurboXS site.
http://turboxs.com/utec350zupdate.htm
all the stuff that you will need is there - including a few base maps for a tuner to "start" from
#127
We found them but couldn't get them loaded on the utech. It was very time consuming but we finally or it done. Now we loaded the base maps and turned the car on and now it doesn't turn on. Pulled the codes
P112 something like thatz Tps sensor stuck open.. So car couldnt be tuned car would start and bog down right away.... Now I need a new Tps....
#129
so we spent about 8 hours getting everything set and now the cars tps sensor is bad. the car starts and just shuts off. what else can it be? the code said throttle positioning not function or something... so im sure that is it..but just to cover all my grounds and i can research it until monday, what else can it be?
#130
TPS is inside the Throttle Body
if you jacked with that at all while it was plugged in and connected to the battery its possible you tweaked something.
Put it in MAP 0 (runs off ECU only) and do a idle volume relearn procedure reset as well as the throttle closed position learning. do a search, if you dont know how to do it.
#131
#135
