Drive Belt Replacement
Old Feb 1, 2011 | 05:15 PM
caideN's Avatar
Hello. I watched the video on Infinitihelp on replacing a drive belt (http://www.wonderhowto.com/how-to-re...5-263051/view/) .
Do I really need the tension gauge? I searched and most people say all I need is a 14mm socket and wrench to loosen the pulley and the 2 tension bolts then take off and replace / retighten.. Just that straight forward?
Thanks
Old Feb 3, 2011 | 12:04 AM
caideN's Avatar
No one?
Old Feb 3, 2011 | 06:58 AM
Blue Dream's Avatar
I drove ttrank's car solo
I replaced my belts earlier in the year with a friend and we didn't use a tension gauge. Just tighten the belts until they have little to no slack and you should be good to go. If they squeak they're a little too loose so tighten a touch more. I've put 15,000 miles on mine with no issues or noises.
Old Feb 5, 2011 | 12:36 AM
ldg870's Avatar
I just replaced mine a couple weeks ago. I pushed down with moderate pressure on the belt. 3.5mm-4.5mm on the alt belt and 8mm-9mm on the ac belt.
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
itschuckster
Jul 25, 2015 08:07 AM
