CRANKshaft position sensor location (NOT Camshaft)
Old Aug 28, 2014 | 08:35 AM
  #31
UR2EZ's Avatar
Nissan 23731-AL60C, Engine Crankshaft Position Sensor $80 on Amazon and prime eligible
by Nissan
Link: http://amzn.com/B00BFE1V80
Old Sep 15, 2016 | 03:46 PM
  #32
G35CO's Avatar
Do i need to drian the engine oil if I'm replacing the sensor?
Old Sep 15, 2016 | 04:02 PM
  #33
g35man04's Avatar
CLUB MODERATOR
No it's at the bell housing and engine where the trans bolts up. Just remove 10mm and swap
Old Sep 17, 2016 | 06:08 AM
  #34
Blue Dream's Avatar
I drove ttrank's car solo
Holy **** Chris, you're still around??
Tanks for you insight as always...........
Old Sep 18, 2016 | 05:39 PM
  #35
G35CO's Avatar
I replaced the sensor, very easy job.
I noticed that the sensor I pulled from the car didn't have o-ring but the sensor I bought have the o-ring. I installed the new sensor with the o-ring but now I'm wondering if I should remove the o-ring.
What you recommend? Thx
Old Sep 18, 2016 | 05:42 PM
  #36
Urbanengineer's Avatar
Old one maybe still on bell housing?
Old Sep 18, 2016 | 07:17 PM
  #37
G35CO's Avatar
No, i checked.
It's not a tight, feel like it's not sealed. I double check and match the new and old and both felt the same and look the same.
Old May 20, 2019 | 09:07 PM
  #38
MoonlightG35's Avatar
G35 coupe 6mt VQ35DE Rev
Originally Posted by g35man04
im not sure what your referencing or anything and I have looked at the back of the motors damn near 30 times now with wire tucks and pulling out mine and doing swaps and I know there are only 2 sensors on the back of each head both being the CAM shaft sensor. I have replaced mine both knowing this.
Take a picture of it for us please.....Thats the only way we can assist.
back of drivers side head/valve cover etc.
Attachment 218404
passenger side
Attachment 218405
On the back of the rev up it runs 4 sensors, unlike the standard VQ35de engines, the 6mt version from 06 and up have the rev up edition engine which has more sensors, and other mess on it.
Old May 21, 2019 | 06:49 AM
  #39
Blue Dream's Avatar
also noticed this....there are 4 cam sensors on the revup
I also see 4 holes here on the motor. You should have 4 cam sensors and the crank shaft sensor should be down below like referenced above.
http://forums.nicoclub.com/fs-vq35de...k-t458662.html
While we appreciate helpful posts we also ask that all members read through whole threads before replying to a particular post. You'll notice he followed up with a post that clarified exactly what you brought up. Also while it's great you searched old azz threads there's no need to reply to an 7+ year old thread, the forum's cluttered enough as is.
Old Aug 3, 2019 | 12:55 AM
  #40
Kyronsk8's Avatar
G35 Coupe. Plenum spacer, k&n filter, z tube. Muffler delete.
Hey sorry for bringing this back up but I'm having crank sensor issues and I'm wondering if the o-ring should be taken off. Original one didn't have one but the OEM one ordered had an o-ring on it. Now I can't accelerate heavily without "hitting a rev limiter" type of thing/issue. Thanks
Old Aug 3, 2019 | 05:05 AM
  #41
Scorpi0's Avatar
It should have an O-ring. Make sure it isnt stuck inside the hole.
Old May 13, 2020 | 01:24 PM
  #42
Jason Taylor's Avatar
INFINITI G35x AWD SEDAN
Originally Posted by the_sedan
under the car between the engine/trans on the driver side. easy to change out. you can jack up the driver side of the car and get to it from behind the front wheel.
for 07 sedan models too? I don’t see it at all
Old May 13, 2020 | 01:43 PM
  #43
Kyronsk8's Avatar
You have a different engine, hr engine so the mounting point of the crank shaft sensor may be in a slightly different location. Sadly I have little knowledge of hr engines so your best bet is to search vq35hr crank shaft sensor location
Old May 13, 2020 | 05:40 PM
  #44
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I can't remember exactly but I think it's on the right side (passenger side USDM cars) and a little higher up on the block, right below the heads I think.
That's where is was on my in-laws old Infiniti FX anyways.
kohartb
Jul 3, 2021 11:39 AM
DGrantG
Apr 23, 2019 08:48 PM
TO33
Oct 21, 2018 02:56 PM
DeanBlack
Oct 5, 2016 06:18 PM
03 G35
Feb 15, 2015 02:45 PM
