Overheating Issue
#32
this problem sounds like a headgasket failure.
#33
Holy SH*T....someone please help. I think I just efft up my car. I got my fan issue fixed by the dealership under warranty a couple of weeks ago. Then all of a sudden, my temp needle shoots up to H as I'm driving then a hear a noise and all of a sudden my check engine soon light comes on. I immediately pull over and turn into a parking lot but my car starts bucking. I find a spot and let it sit for a half hour to cool off. Temp needle is basically staying at H. Luckily my house was less than 5 mins away. But it continued to buck and vibrate and I could hear a rattling or something from the engine and just as I pull in my driveway, the car completely shut off. WTF could've went wrong? I mean the issue was just "fixed" by the dealer and now it starts overheating. Somebody please tell me something, I'm awestruck right now
#34
#35
FML this can't be happening.
I'm assuming the service department isn't open on Sundays so I would have to wait until Monday right? Is there a statute of limitations or something, because it hasn't even been a month yet since it was fixed. Everything was fine when they fixed it for a few weeks, now....
#36
I would suggest call them ahead of time and talk to them politely and see what they said, if they refuse ask to talk to the service manager and then get belligerent...lol
#37
that might have to work. The service dept rep that I worked with last time was pretty cool, so hopefully I wont have to get belligerent. lol.
But any ideas on what the issue could be? The fans were the issue last time, and they clearly work, or from what I can hear...however it still 'overheated'.
#38
Next time you leave the dealer after they work on your car, take a minute to look over your car, specially whatever part they work on. I usually look around my car to see if they scratch anything then I pop the hood and look around for any loose connections and test whatever system the worked on. In your case I would of turned the car on and verify the fans come on when they were suppose to and the coolant level was within limits. Good luck
#39
Do you think it could be a head gasket? I have a bad feeling that's what it is. It went limp and then the service engine light came on and the needle stayed at H. I have 93K miles on my car and the dealership "fixed" my previous overheating issue because the cooling fans weren't working. What are the changes they'll diagnose the problem for free since it's only been two weeks since they fixed it
#42
When the car is cool, check the radiator... if it looks like chocolate milk = oil in water.
Check oil dip stick, if choc. milk = water in oil.
If you see water vapor after FULL warm up in rear exhaust = Water in Combustion Chamber (Typical characteristic for water being pushed out of reserve tank and overboiling)
#43
I saw a little bit of water vapor or a little white smoke after start up and a little revving...but it went away. I let it idle for about 5 mins or so and the needle stayed at the bottom. I decided to take it for a one mike spin around my neighborhood. For the first half mile, the needle stayed in the middle, then when I stopped to make a u-turn, it started creeping up towards H again. It stayed relatively close to the top but never passed the last notch before H. Pulled in the driveway and shut it off. The dealership is about 15 mins away (mostly highway) and the mechanic I usually take it to is about 15 mins in the other direction, not so much hwy. Lol.
I called Infiniti this morning and of course they said bring it in, but they said it wasn't a cooling fan issue since they were brand new and 3 weeks old and I know they're about to rip me a new one
#45
Problem solved. Appreciate everyone who chimed in. I took it to my local mechanic. Apparently, the dealership forgot to tighten the valve back there behind the engine when they replaced the fans so my coolant was leaking out. WTF. The dealership is so ****ty. Almost had to make me replace my whole engine.
