Replacing the spark plug well seals in the valve covers
Old May 6, 2020 | 01:52 PM
  #181
JoshD4PREZ's Avatar
Custom full exhaust, Ztube, fresh clutch & dmflywheel, staggered niche 18's
That seems very possible, well thank you I’ll check it out when I get it opened up then.
Old Jul 14, 2020 | 04:56 PM
  #182
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Originally Posted by FreshLikeAG
I saved my oem valve covers when I switched them with some cheapo brand. Passenger VC gasket is leaking again so I'm going to put the oem ones back in. Seems people have had success with rtv on the seals
I'm about to attempt this as I found oil in the #5 and #6 tubes when I went to change plugs. Are you waiting a certain amount of time, or even letting the Ultra Grey fully cure, before putting the valve covers back on? Any reason why you didn't put any on the inside of the seals where they meet the spark plug tubes? I guess I don't fully understand where the seals are failing and oil is getting by. Judging from this picture I guess they fail where they seat inside of the VC?
UPDATE: Nevermind. I ran across a post from last year by scumbagsleeper that detailed what he did that answers my questions.
Old Nov 7, 2021 | 01:17 AM
  #183
Scorpi0's Avatar
Found a video with someone who came up with a faster fix. He basically uses RTV to seal the tubes from the outside instead of the inside. This will probably be a lot easier for most people. The seal probably wont be as strong vs doing it from the inside, but RTV black is a damn good sealer and I think it will still work well and save a lot of time. Plus with this method you wont have to mess with any other gaskets.
Old Nov 7, 2021 | 07:59 AM
  #184
TITANG9's Avatar
G35 RWD AUTO
After 9 years, and NOW you are telling me this..///LOL
Nice man....PERFECT....
adrians07z
92
Nov 6, 2024 06:11 PM
R&DFactory
60
Jul 31, 2021 04:05 PM
R&DFactory
Engine-Vendor
40
Aug 10, 2015 07:26 PM
MikeGrote
Aug 10, 2012 11:35 PM
MM_G3520
24
Mar 7, 2011 11:41 AM
