Passenger Valve Cover Clearance Issues
Old May 22, 2011 | 04:32 PM
XDR-V35's Avatar
Got the drivers side valve cover off fine, now pulling the passenger one and dont have enough clearance due to a bracket on the main wire harness at the rear, see pic. Drivers side was easy as I just removed the entire harness, this side I cant.
Old May 22, 2011 | 04:47 PM
GreenGoblin's Avatar
The goblin resurrection
iirc there is a bolt holding that bracket on
Old May 22, 2011 | 04:58 PM
XDR-V35's Avatar
the bolt only goes through where you can see the hole, so bracket is not bolted, i have about 1" of play but not enough to clear the cams with the covers.
Old May 23, 2011 | 12:03 AM
onthe3rdday's Avatar
Thats a tight spot but I remember that once everything forward of that part of the harness was removed, you get an extra 1.5 inches...Thats about all youre gonna get. I'm looking @ the pictures from when I did it right now, and maybe even 1.5 inches is generous!
Old May 23, 2011 | 12:18 AM
Tollboothwilley's Avatar
It is a tight fit - but I pulled it out of the way slightly as I slid it into place. Scratched the paint in one little spot but other than that I made it work. Tight spot though.
Old May 23, 2011 | 08:37 AM
XDR-V35's Avatar
Thats going to be a PITA to put back on and keep the gasket in place.
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
yassy
Aug 9, 2015 07:31 PM
Ken167
Aug 7, 2015 11:12 AM
lemmy999
Jul 25, 2015 12:13 PM
Ashton35
Jul 22, 2015 09:19 PM
