Urgent help please! Engine turns about 3/4 turn, stops.
Old Nov 8, 2011 | 03:52 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The shop doing my engine replacement just came up against a brick wall of sorts. Everything installed, they went to turn it over, and it went about 3/4 of a rotation and just stopped completely, both with the starter and with manually turning the engine.
Any ideas on what this would be? I hope it's something simple.
Old Nov 8, 2011 | 03:58 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
hey Brett, we think that might be a bent connecting rod
Old Nov 8, 2011 | 04:08 PM
It's a "new" remanufactured engine, if it's a bent rod, that would be pretty aggravating, as that's what's wrong with the engine I'm replacing.
Also, another reason I wish that engine from you guys hadn't been ruined by the shipper.
Anyone else have an idea of what it could be?
Old Nov 8, 2011 | 05:14 PM
saywat?'s Avatar
bad sensor somewhere maybe?
Old Nov 8, 2011 | 05:16 PM
Doubt it, that wouldn't prevent you from turning the engine over manually.
Old Nov 8, 2011 | 05:32 PM
PREMIUM SPONSOR
Yeah man, you and me both! I will ask one of our experienced techs and see what they say
Old Nov 8, 2011 | 05:35 PM
PREMIUM SPONSOR
Ok, my guys says, to look in the spark plug holes, and see if there is water in them.... if not, said the engine might have been sitting for awhile and built up crud around the pistons, and said to spray wd40 in each of the cylinders to break it free
Old Nov 8, 2011 | 06:08 PM
Vegas4DR's Avatar
eek!
Good luck with this
Old Nov 8, 2011 | 07:57 PM
definitely no crud or water in there. I'm really hoping it was just a valve with off-timing at this point.
Old Nov 9, 2011 | 10:33 AM
Z1Motorsports's Avatar
Sounds like your Timing may be way out of wack, causing the valves to hit the pistons.
Goodluck!
-Rob
Old Nov 9, 2011 | 11:47 AM
slim17265's Avatar
wrong throw out bearing and not releasing the pressure plate enough, also check to see if line to throw out arm needs to be bled (air) causing not enough release
fianlly have someone watch to see how much throw out arm moves
Old Nov 9, 2011 | 09:31 PM
I'd considered something with the clutch myself, it's not a replacement clutch, so the throwout bearing is the same as before. If it's in neutral when the engine is attempted to be turned, will this eliminate the throw out arm as a possible cause?
Old Nov 9, 2011 | 09:33 PM
Oh, and update, I got word that it possibly rotated completely around today, but the tech wasn't able to put much time into the car.
I should know by noon tomorrow.
Update:
Car's good to go. Not sure what the problem was that kept it from turning initially, but it's running pretty good now. The month-old gas seems to make the car make a small "puff" sound randomly, or it could be a sensor that didn't take too kindly to the water. No codes at all though, so I'll just bring it up with the shop when I visit them tomorrow to deal with the old engine, and hopefully find out what the problem with it turning over was.
There was also a misaligned shifter plate that made 5th and 6th gear nearly impossible to find, but I took care of that myself.
Old Nov 11, 2011 | 09:15 PM
Epilogue:
Still not sure why it didn't turn over, but it's running OK now. Sometimes make little "puff" sounds out the exhaust, but I'm just blaming that on stale gas (6 weeks) for now, as it seems to be getting better.
There was some pretty bad rattling sounds coming from the bell housing for a little while, but that seems to have stopped. Possibly just the dual-mass settling or something?
Jiggerjuice
Oct 5, 2015 02:33 PM
zcherub
Aug 30, 2015 05:04 PM
Jroc2017
Aug 12, 2015 11:21 AM
