Valve Cover Gaskets
Old Jan 16, 2012 | 06:52 PM
03GT35R's Avatar
Valve Cover Gaskets
Hi guys i have 03 G35 sedan, I have never had to replace anything on my engine before. All has been well until i noticed a burning oil smell a few days ago...after further inspection, it appears that my valve cover gaskets are leaking and dripping on the factory exhaust manifolds and burning off causing a nice hot burnt oil smell... Has anyone changed these? Just from looking at it, it appears the upper and lower intake will have to be removed for this. Can anyone confirm?
Also, i ll be doing some preventive maintanence and upgrading my radiator, does anyone know if there is a kit to remove the fan clutch and plastic blade fan on my 2003 G35 Sedan?
Old Jan 16, 2012 | 07:06 PM
redpearl99's Avatar
1) remove upper and lower plenum
2) remove valve covers
3) apply new valve cover gaskets
4) reassemble everything
Old Jan 16, 2012 | 07:17 PM
Frankieg35's Avatar
Not hard at all even if u don't know much about cars.. Lol
Old Jan 16, 2012 | 07:25 PM
redpearl99's Avatar
I forgot to mention that you also have to RVT the corners
Old Jan 17, 2012 | 04:53 PM
blackout2277's Avatar
I did this in about 45 minutes in the middle of the night and I really don't know much of **** about cars. Go for it
Old Jan 17, 2012 | 05:35 PM
Dsskyline's Avatar
Not hard just remove the items stated above, but make sure you cover your intake holes after removing the lower plenum.
If you drop a bolt or something in one of those holes you will have a serious problem.
Old Jan 18, 2012 | 01:53 AM
chopsuey04's Avatar
The same thing happened to my 04 coupe. The hardest part I see about changing the valve covers is accepting the price of the parts. I keep reading every where I have to change not only the gasket but the both valve covers and that totals up to about $750 at Infiniti and 550 at Nissan.
Old Jan 28, 2012 | 08:02 PM
03GT35R's Avatar
Yeah looks like a piece of cake to do, just wanted to make sure that i wasnt missing anything...Did you guys replace the intake manifold gaskets as well when doing this?
Old Jan 28, 2012 | 08:17 PM
chopsuey04's Avatar
I was going to ask the same question because I just ordered the Valve Covers and their gaskets. Do I need any other gaskets?
Old Jan 28, 2012 | 08:35 PM
suprasam's Avatar
no other gaskets are needed just a tube of RTV for the front corners of the valve cover. easy job.
Old Jan 28, 2012 | 11:45 PM
ryanm8's Avatar
I'm trying to replace the passenger side valve cover right now. I'm having a hell of a time reaching the bottom corner bolt in the back. There's a wire harness and radiator hose in the way. There doesn't seem to be any way to remove the wire harness. Anyone replaced the passenger side and have some tips?
Old Jan 29, 2012 | 09:54 AM
03GT35R's Avatar
Not sure if you have done this or not, but make sure that you have unbolted the wire harness from all brackets, and unplugged it all, so that it has more play in it vs. being stiff and attached to all the plugs.
Old Jan 29, 2012 | 11:56 AM
ryanm8's Avatar
I'll try that. Thanks!
Old Jan 29, 2012 | 01:15 PM
03GT35R's Avatar
I posted that before i got started on the intake & valve cover removal, if the taking the harness loose didnt work. I found that you must use a swivel adapter with extension on the 10mm bolt that is on the left/right side very back bolt closet to the firewall.
I just changed all my plugs to NGK Iridium plugs, changed the lower intake manifold gaskets from the stock ones to the thermal thicker gaskets, and installed the new Skunk2 intake spacer on the upper plenum intake & installed the new valve cover gaskets, dont forget to use RTV on the front corners. Big Thanks to Mike at www.kteller.com for hooking me up with the new Skunk2 intake plenum spacer.
I m gonna let it sit overnight to let it all set, so the RTV can dry and seal.
While that is setting, I need to do my Synthetic oil change, & i m changing out my rear diff gear oil to Motul Synthetic Gear oil.
Waiting on my new All aluminum Radiator to get here next week.
Old Jan 29, 2012 | 03:33 PM
ryanm8's Avatar
Thanks man! Taking the bolts off of the whole harness helped give an inch or two more room to work with. I was able to finally reach the bolt with 2 wobble extensions linked together... Phew. Should be smooth sailing from here.
