unichip available for G35 and 350Z
Old Jan 3, 2005 | 03:49 PM
jcv's Avatar
jcv
Talking unichip available for G35 and 350Z
If anyone is interested, seems the Unichip piggy back is available for 03-05 G35 AT and MT.
http://www.v6performance.net/store/p...64429c978a6839
Old Jan 3, 2005 | 03:54 PM
neffster's Avatar
Does this include the new ECU updates for the 2004.5's? If so, how does this piggy back system work? Is it set up to work with specific mods? Does it need to be programmed initially like the TS ECU does? There seems to have been a lot said about this piggyback, but there nothing about how it works. Also, how come this thing is SO EXPENSIVE? The ones for the honda's are several hundred dollars cheaper. It looks like they are just gouging the Infiniti owners because our cars cost more...
Someone from Unichip better chime in soon!
Old Jan 3, 2005 | 03:56 PM
jcv's Avatar
jcv
Go here for info http://www.unichip.us/
This is the same system APS uses for their TT setup.
Old Jan 3, 2005 | 03:57 PM
roneski's Avatar
Devil's Advocate
I'd love to hear more about it. I just don't want to be the first. Any other data available? Their website seems a little sparse about specific application info.
Old Jan 3, 2005 | 04:07 PM
neffster's Avatar
Straight from the Unichip website...
Unichip typically produces a peak power gain of between 5-9% and provides an increase at all rpm.
If this is true then my 301 bhp G35 should gain a MINIMUM of 15bhp and as much as 27bhp. What type of guarantee is there?
How does it do it? The gains result from the Unichip’s tight, accurate map sets that correct the Air-Fuel ratio and timing to produce maximum power.
So they have cracked the code for the 2004.5 ECU's? It sounds like a good marketing driven message, but where is the PROOF?
I'm spending $1200 on a set of Crawford Headers. They've been dyno proven by many individuals to give a 20bhp gain over stock (and 40bhp with the plenum and cats)... If I spend another $800+ will my 320bhp vehicle G35 turn into a 340-360bhp machine? This means I'd be nearing the M3 territory. It just sounds "too good to be true".
Someone please help me with this!
Old Jan 3, 2005 | 04:57 PM
Msedanman's Avatar
O.F. Administrator
Looks like a 'tuneable' system like the TS reprograms, but more expensive.
Old Jan 3, 2005 | 06:41 PM
jcv's Avatar
jcv
Unichip has been around longer than Technosquare (.http://www.dastek.co.za/ ) They are pretty well known on Hondas, etc.The nameless forum on the first listing has a thread on R&D with 6th gen Honda V6's.
Neffster, if you've kept up with the APS TT in the 350z forums, that system uses the Unichip.
http://www.airpowersystems.com.au/unichip/unichip.htm
One of the things that is interesting is it stores original configuration so you can revert at will.
Old Jan 3, 2005 | 07:06 PM
FLFIRE's Avatar
I think I will wait until they learn to spell the name of my vehicle before I consider buying their chip. Do a vehicle search on their web site for the Dyno Data Applications and you will see what I mean.
Old Jan 3, 2005 | 07:22 PM
jcv's Avatar
jcv
Flfire, other than the US, there is no Infiniti so it's not surprising. Also, many people on the G forums don't know how to spell it either.
Old Jan 3, 2005 | 07:41 PM
neffster's Avatar
I would not buy this product w/o someone coming here and explaining it a little better (or atleast explain it a little better on their own website). Do you really think the VQ35DE has another 15bhp (minimum) hidden inside of it? Or maybe 20-25bhp with NA mods?
Does this raise the rev limiter? Remove the electronic speed limiter? etc...
Old Jan 3, 2005 | 07:59 PM
jcv's Avatar
jcv
15 bhp, probably. Even Technosquare claims that. More, hmmm.. Far as I know the rev limiter is raised and mixture/timing maps altered. Dastek Unichip is well known in racing circles in many different makes (European, US, etc) for NA and FI. Should be a dealer in your area you can talk to and probably get it tuned at.
I like the idea of a piggyback and locally programming much more than Technosquares's mail-in special that leaves me cold. Technosquare is okay for CA locally. SGP does reprogramming in Houston using the Techtom programmer.Still undecided. If only the Unchip was little cheaper..Maybe a GB?
For more info, just do a Google search (ignore the unichip for servers) and you'll find plenty of references including race teams (prototypes, autox, etc).
Old Jan 3, 2005 | 08:18 PM
RBull's Avatar
Rated M
__________________
I always tell the truth, except when I lie.
Hey JVC The Infinti brand isn't reserved just for the U.S. We Canadians also have the pleasure of owning this fine car.
BTW I had the same thought as Flfire when I went to their site.
Cheers
Old Jan 3, 2005 | 08:32 PM
jcv's Avatar
jcv
Ooops, damn I forgot the frozen North. and it's Infiniti
Old Jan 3, 2005 | 08:56 PM
RBull's Avatar
Rated M
I wanted to see if you were looking! I guess you're right about people here not being able to spell the Infiniti name either. But then again I'm just a hack playing around on this web site and am not representing a professional U.S. aftermarket auto company appealing to knowlegable car owners.
Damn I'm sorry I didn't catch the JVC earlier though, JCV
Cheers from the stereotyped great white north
Old Jan 3, 2005 | 09:12 PM
jcv's Avatar
jcv
Least you're not from MooseJaw, like others I know.
http://tenderbytes.net/rhymeworld/lo...e.htm#macmoose
Don't want to say what vandals do to Mac the Moose's privates
