knock sensor harness?
Old Jul 23, 2012 | 10:46 AM
tashspop's Avatar
i've got the p0327 code and will be ordering a knock sensor for replacement, but after searching and reading, it seems common that my issues could be in my harness. i can't seem to find a harness anywhere, so my question is does anybody know where i could get one at?
also in doing this swap/repair, will i need to order any gaskets or anything for my intake?
thanks
Old Jul 23, 2012 | 06:21 PM
Tolboothwilley™'s Avatar
i dont even know where the stock knock sensor is located...but removing the intake/TB/upper plenum/lower plenum/intake runners all have gaskets that you can reuse... so you should not have to order any new ones.
As for the harness, i have a harness out of a 2006 G35 rwd sedan. It is a FULL harness for the entire motor that I have. I'd be willing to sell it but not sure what section is the knock sensor section.
Old Jul 23, 2012 | 06:36 PM
JaE35's Avatar
Moderator
G35 Sedan
It's very rare the sensor goes bad and you are correct, replacing the harness fixes the issue...i went through hell with this a while back. It's connected to the injection harness and clips off, z1sells the complete fuel injection harness with knock connector...i'll link you in a second only ran me 60 bucks to fix
Old Jul 23, 2012 | 06:37 PM
JaE35's Avatar
Moderator
G35 Sedan
http://www.z1motorsports.com/350_g35...oducts_id=3189
that's it...they temporarily sold the knock harness by itself for less but looks like they stopped doing that
Old Jul 24, 2012 | 08:31 AM
tashspop's Avatar
its just the section with the blue clip i need right? is this one better built than the factory piece? i'm wondering if i can just re use the clips i have and use better wire to make my own repair. i've already planned on putting a meter on it when i get under the hood.
Old Jul 29, 2012 | 08:07 AM
tashspop's Avatar
i got lucky and the $29 knock sensor i got from local parts store fixed my issue, no need for a harness. once i got in there i found that it was easy enough that i could chance putting it back together without replacing the harness and take the chance of repeating the repair if needed.
Old Jan 2, 2013 | 04:55 PM
dr_scifi's Avatar
do you have a how to in replacing the knock sensor? I got the sensor and would like to do it myself, Any suggestions?
Old Apr 15, 2020 | 06:07 PM
mckenzieplumm's Avatar
infinty g35
where did you find the complete kit please send it to me lookin for it.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
