My G is acting silly!!!!!!!!!!!!
Old Aug 20, 2012 | 11:27 PM
bluedevils95's Avatar
Unplug the negative one.
Old Aug 21, 2012 | 02:05 AM
Tolboothwilley™'s Avatar
Quick reset by disconnecting the negative and depressing brake pedal several times
Old Aug 22, 2012 | 08:38 PM
javdj2fan's Avatar
Originally Posted by jcseven7
Well hell... Before you spend the cash replacing your MAF, reset your ECU. You might get luck, it may clear up your issue for the free.
I did try both methods. Nothing worked. I tried the disconnect, left it over night and I tried the pedal method. Got the the timing down perfect (light blinked and all) but no change.
Old Aug 22, 2012 | 08:43 PM
javdj2fan's Avatar
Originally Posted by Mr. Brett
It's in limp mode. Search around...there are a lot of threads on this.
Did you pull the SES code? It's usually something like the MAF when the car goes into limp mode and you experience high idle. Your throttle body may have gone out by chance, too...not as likely, but it has happened before.
I found an aftermarket MAF for cheap but I've been told that I must buy a OEM Infiniti one. Is this so and why? Aren't aftermarket parts made to OEM specs?
Old Aug 23, 2012 | 09:30 AM
jcseven7's Avatar
Sorry bro... it was a long shot, but one worth taking before moving on to parts and labor.
OEM or not, the MAF is one piece with no moving parts. It's either going to work, or it's not. If the MAF you are looking at says it works for the year G35 you drive, it's built to spec.
Take a moment and read this just to get more familiar with the part and it's purpose, LINK. Being well informed will help you draw your own conclusions and guide your decisions.
Old Aug 23, 2012 | 11:59 PM
javdj2fan's Avatar
Replaced the MAF. Started up at first and idled fine. It would even rev past 2200 RPM as it was not doing it before. VDC light and slip light was off. Did the ECU reset to get the SEL light off because it was still on and now it will start but not rev past 1100 rpms. I can floor it and it feels as if I were not doing anything and VDC and Slip light came back on. Did the whole pedal position thing and still the same.
Old Aug 25, 2012 | 03:51 PM
jcseven7's Avatar
any new codes? you sure you did the ECU reset correctly?
Old Aug 26, 2012 | 05:07 PM
SUMATIC's Avatar
where did you buy the MAF from and did you purchase the right one? put your original one in and see if you can get it to rev past 1100 and if so id stick to that one. Or buy an OEM MAF to be on the safe side.
sounds like your car went in to limp mode.
AT23
Sep 15, 2015 07:44 PM
Terry_G35
Sep 10, 2015 08:17 PM
