About To Hit 100k miles
Old Oct 10, 2012 | 10:18 PM
03XG35's Avatar
Im about 47 miles short of 100k. what needs to be done. Auto 03 coupe
Old Oct 10, 2012 | 10:30 PM
Footballmania32's Avatar
Spark plugs, PCV valve, belts, inspect brakes, inspect shocks and struts. Inspect your lower control arm and compression rod bushings. Air filter, in cabin air filter, coolant flush, inspect your valve covers when you change your plugs. If you find oil, replace your valve covers. Transmission fluid drain and fill, differential oil change. That's a good idea as to what to get done.
Old Oct 10, 2012 | 10:37 PM
jninja26's Avatar
^that
Old Oct 10, 2012 | 10:44 PM
03XG35's Avatar
SOme please point me to a online link where i can order spark plugs. nissan dealership was way expensive
Old Oct 10, 2012 | 10:54 PM
faiz23's Avatar
wtf...lazy.
sparkplugs.com
Old Oct 10, 2012 | 10:56 PM
03XG35's Avatar
Well i dont know if theres a certain type i should use or anything
Old Oct 10, 2012 | 11:14 PM
jninja26's Avatar
yes, there is. The oem NGK Iridium plugs. Go to an Advanced Auto or O'reillys, it's usually around the same price as whatever you might find online. I spent about $50 on mine, 3 times so far...don't ask..
Old Oct 11, 2012 | 10:22 AM
JaE35's Avatar
Moderator
G35 Sedan
go walk into an auto store like autozone locally and give them your year and model...they can get you the oem plugs for half the dealer price
Old Oct 11, 2012 | 11:50 AM
Tolboothwilley™'s Avatar
OEM is NGK platimum laser....lots of people like the Iridium though
Old Oct 11, 2012 | 01:42 PM
maclovio's Avatar
I'm scared of hitting 100K. I am currently at 72K on my 07 Coupe. I'm thinking of buying all that stuff needed just so it won't impact my pocket when the 100K mi come.
Old Oct 11, 2012 | 02:59 PM
Subiedrewbie's Avatar
Since you have auto you can flush the transmission... That's always up for debate. 6mt it's better to drain and fill. This is based off threads I've read when looking what to do with my 6mt fluid a couple months back.
Old Oct 12, 2012 | 09:30 PM
RADRaze2KX's Avatar
^ x2, I hear flushing your transmission after a certain point can do more harm than good.. I'm at 150K and never done a transmission flush, but I'm running stock everything..
I did spark plugs, accessory belts, brakes, air filter, in cabin air filter, coolant flush, oil change, all at ~95K... You're almost guaranteed to find oil in spark plug #6 tube https://g35driver.com/forums/g35-cou...rranty-up.html ... I found a small pool in mine, so before I pulled the old plug out, I soaked up as much oil in the as I could, then removed the old plug and took out the remaining oil from the #6 tube, gapped and installed the new spark plugs, no issues...
Hell, my G just hit 150K miles and still gets 28.5MPG @ 65MPH when I draft behind semi's for extended periods of time...
Old Oct 12, 2012 | 09:52 PM
PAIXAO's Avatar
I'm at 130k. My car runs stronger than she did at 30k. No worries when it comes to mileage on these engines. Take care of her and she will take care of you!
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
nosam1g
Aug 22, 2015 11:58 PM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
