Engine Whine - In neutral or in gear, but goes away when clutch depressed
Old Dec 24, 2012 | 04:52 PM
wallofgrath's Avatar
Sorted it out
Old Dec 30, 2012 | 01:34 PM
mrgrey's Avatar
Same problem, Aamco told me it was the front bearing in the trasmission.
Old Dec 30, 2012 | 04:34 PM
Please delete
Old Jan 4, 2013 | 01:34 PM
JLsG35's Avatar
Unhappy
I've got the same problem, with almost 250,000 kms, plus a nice cold Ontario winter, it squeels even louder now but goes away after it gets warm. After taking it a reputable shop, was told basically need a new clutch.
Old Jan 4, 2013 | 02:12 PM
If you have the exact same problem I described, then it's probably NOT your clutch. I replaced mine and nothing changed.
Your whine goes away when clutch is depressed? Might just be your accessory belts if it goes away when the car warms up...
Old Jan 7, 2013 | 09:37 PM
vipv35's Avatar
Throwout bearing
Old Jan 7, 2013 | 10:36 PM
No, throw out bearing makes noise when you press IN the clutch.
11bEMT
May 27, 2022 03:13 PM
.cakestar
Jul 28, 2017 07:09 PM
zcherub
Aug 30, 2015 05:04 PM
zcherub
Aug 27, 2015 09:47 AM
