Motordyne Plenum Spacer Vs Crawford V5
#31
#32
Originally Posted by pdjafari
Ya, im curious about A/F as well. Also curious in the diff. in performance for a 1/4, 3/8 etc. what material is it made from, plastic?? how durable is that?? I mean it is almost $200 for the spacer...and if in fact crawford is coming out w/ a new plenum as neffster mentioned...which allows you to keep the core and is much cheaper...id ike to know how much cheaper...$200 just seems a lil high for a piece of plastic....i dont doubt the product...just a tiiiiny bit skeptical...im gonna have to wait on this one...until i get some more feedback.
I'll get AF plotted. As far as differences are concerned, they are pretty close in HP. On my car, testing indicates the 1/2" produced ~3.5HP more than the 1/4".
And no, it is not made of plastic. It's all aluminum 6061 T-6.
From the number of questions I've been getting it emphasizes how important it is that I get a website with a FAQ section up and running. A website is comming soon.
I also recieved approval for sponsorship on G35Driver. I'll be able to set up a section giving a much better description of everything. This should help a lot.
#34
Originally Posted by Hydrazine
Could sombody please ask the Admin to contact me about becoming a G35driver sponsor? I sent several emails but havn't had any luck so far.
I wanna to sign up for sponsorship!
For more information on Motordyne Plenum Spacers give me a PM or email at MotordyneEngineering@dslextreme.com
Your plenum spacer looks very interesting.
Colin (GSM)
#38
Originally Posted by nuttyprof
ok, last 2 posters, im sure hydrazine is sick of writing this so here:
the website is not up yet.
and it will be about 195 estimated.
#41
Dizz,
Sorry, I would have answered your question earlier but was pulled out of the office.
Yes. The 1/4" spacer will fit under the V5 when installed in the G35C. E_K is running the combo in his car now.
But this is cool, you're off to a great start with good customer service.
So when you sell your spacer, are you including hardware and gaskets?
#42
This looks FANTASTIC!!!! Great job Hydrazine!
Now, all I have to do is determine which size to get.
I've read all of the posts including the Group Buy post and am trying to determine what each size delivers in both Hp & Tq.
1/4" & Stock Plenum--- Hp Increase ?? Torque Increase ??
3/8" & Stock Plenum--- Hp Increase ?? Torque Increase ??
1/2" & Stock Plenum--- Hp Increase ?? Torque Increase ??
What I'm trying to determine is below you state that the 1/2" gives about 3.5 hp increase over the 1/4".....so I would assume the 3/8" gives a hp increase in between these? What about the torque increases? I like the idea of the 3/8" allowing for clearance under the G35 cover leaving a stock look but giving hp & tq increases.
Also, how much hp does using the 1/4" spacer add to the CV-5 plenum? I am trying to decide if it makes more sense to buy the 1/4" AND the new Aluminum Crawford Plenum and get more hp & torque!
Thanks.....this looks great!
#43
Originally Posted by E_K
The spacer I'm using now is aluminum. I'm using a gasket below and above it, so the seal is pretty good.
My A/F was about 14 at peak using this dyno. I don't think the A/F reading with this method directly corresponds to A/F with dynojet readings, so I can't make any further conclusions on this.
I don't have the data in front of me now, but I can plot the A/F tomorrow.
#44
Originally Posted by Randys_G
Was this reading from the tailpipe or pre-cats? If it's at the tailpipe, a 14 isn't a lean condition as the exhaust gases are leaned out as it goes through the exhaust system...a 14 at the tailpipe is closer to a 13.5 pre-cat, which is great for a N/A G. I wonder what this mod would do for us SC'ed guys? Too lean?
Here's the air fuel ratios. The green line is the A/F from the dyno day in Sept, I was in 4th gear in that run, the rest are in third, if that makes any difference.
Here's the torque curves. Again, the dyno day run was in 4th, the rest are in 3rd.
Sorry that my series are not in order....
#45
