VDC switch problem
Old Jul 26, 2013 | 03:42 AM
whoisthis's Avatar
VDC switch problem
hi, about a year ago i've done this little DIY to switch on and off VDC completely. It worked fine until few days ago. http://my350z.com/forum/engine-drive...bling-vdc.html
VDC is always off now even though i toggle the switch to ON.. so on my dashboard, it's showing VDC off and SLIP light all the time.
I was able to switch to ON and there would be no VDC or SLIP light on the dashboard.
All the wires seemed to be tightly connected to one another. I used to have male/female connectors but changed to butt-connectors to see if this will solve the problem. Problem is still there.
Here's a pic of the wiring.
please help me figure this out
Old Jul 29, 2013 | 01:54 PM
Tolboothwilley™'s Avatar
have you checked your fuses?
with exposed metal on the connectors there, it could have grounded and popped a fuse or anything in the circuit (relay, etc)
the connectors on the switch should be shielded
Old Jul 29, 2013 | 02:00 PM
whoisthis's Avatar
I checked the fuse box. I believe vdc has a "relay" not fuse.
How do I go about checking if the relay is ok?
Old Jul 29, 2013 | 02:34 PM
herrschaft's Avatar
^Apply the correct voltage to the correct lead on the relay, if its good you will hear it click.
Old Jul 29, 2013 | 02:59 PM
whoisthis's Avatar
Sorry I dont know what you mean by that..
I know almost nothing about this kind of stuff.
Old Jul 29, 2013 | 06:02 PM
then find someone with the same car - swap relays and see if that fixes your problem
Old Jul 29, 2013 | 08:35 PM
whoisthis's Avatar
I was actually thinking about that. Would g35 coupe auto 2006 relay work on 2005 350z manual?
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
leo38cheng
Nov 12, 2015 06:49 PM
wonderizm
Sep 24, 2015 03:09 AM
MsFitFern
Aug 9, 2015 02:58 PM
