Fuel Pump Rubber Gasket
Old Aug 18, 2013 | 10:25 PM
Brownie87's Avatar
I recently Put a walbro 255 in my SC G35 and it was all ok until i started to lose fuel pressure bad the guys that tuned my car said that its the rubber pice that slips on the walbro and in to the sending unit. Ive been picking apart the internet and called Nissan and Infinity and i cant get a part number... Do you guys think this evo one would work...
Part Number Mr431121
Thanks
Mike
Old Aug 23, 2013 | 12:20 AM
wallofgrath's Avatar
check dealerdirectparts.com and check if there are used units that include this piece on eBay
Old Aug 24, 2013 | 08:17 PM
fixerbc1's Avatar
I have been looking into this fix as well and decided to buy the grommet and give it a try.
Ill post again once I know if it worked or not
Old Aug 29, 2013 | 07:45 PM
fixerbc1's Avatar
So I received the mitshibishi grommet today and I think it'll work comparing it to the old.
Ill know more once I pull the pump and give it a try
Old Sep 1, 2013 | 10:42 AM
fixerbc1's Avatar
Installed the new mitshibishi grommet today and it fit just fine for me. I did add a little piece of fuel line to act as a spacer/added a little length to seal to help it stay in place I little better.
Ill b firing it up again soon once I complete a fe other projects.
Old Jan 25, 2014 | 04:31 PM
BoostinJaxLR's Avatar
Did that Mitsubishi grommet work? I have the same exact grommet issue.
Old Jan 25, 2014 | 06:11 PM
fixerbc1's Avatar
Been working great, no issues,
Old Jan 25, 2014 | 07:09 PM
perfect, i went to infiniti today and they were useless, trying to explain the only way i can get the grommet is to buy the 412 dollar assembly....which not only do i think is a lie, its a freaking JOKE. I'm stunned this part number hasn't been discovered, we aren't the only ones who have had this issue.
Anyway, after i left there i went down the road to mitsubishi...with the help of brownie87's part number on that grommet, guy said it'd be like 2.50 or something and he could have it here by tuesday....so i think i'm going to grab one.
How much fuel line did you have to use to give it some length? did you just slide the fuel line down the shaft of the pump and then stick the grommet on top?
Old Jan 25, 2014 | 08:14 PM
fixerbc1's Avatar
To make up the gap I used maybe a 1/2" or less if hose.
When u see how much shorter the Mitsubishi grommet is the little piece of tubing will make sense.
Old Jan 25, 2014 | 08:23 PM
you are the man! i've been having issues for years....maybe now i'll finally be able to feel power again. last 3-4 weeks its been completely undrivable! i'm gunna grab that grommet from mitsu and pop it in tuesday.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
