How to clean throttle body (no relearn procedure) ???
Old Aug 28, 2013 | 11:09 AM
68_GT's Avatar
I'm 99% sure I need to clean mine. Car runs fine but dies at start up occasionally. I have 114k miles now.
I know how to physically remove and clean it but I'm concerned about the relear procedure etc..I don't have time for any surprises, or problems.
I thought I saw somewhere that you can remove the positive battery cable before you start then disconnect the wiring clean away reinstall the TB, reconnect the wiring and then the positive battery cable and not have to worry about hanging high idles, or the relearn procedure.
I need to get this done ASAP anyone ?
Old Aug 28, 2013 | 11:25 AM
Urbanengineer's Avatar
See the last page of this doc
http://www.motordyneengineering.com/manual.pdf
Old Aug 28, 2013 | 01:31 PM
MikeDG's Avatar
You are correct 68_GT. I disconnected my negative battery terminal and pressed my brakes 5-6 times, then went on to clean the throttle body. My idle stayed the same afterwards and I didn't have to mess with doing the throttle relearn procedure.
Old Aug 28, 2013 | 03:26 PM
68_GT's Avatar
what does pressing the brakes 5-6 times after removing the battery terminal do ?
Old Aug 28, 2013 | 03:35 PM
MikeDG's Avatar
I've heard that pressing the brake pedal helps discharge any current that may still be in the ECU or electrical systems. In all honesty I'm not sure how much it really does in these cars, but I just do it for extra piece of mind.
Old Aug 28, 2013 | 04:42 PM
Cux350z's Avatar
Its only 2 pots and a motor...........the only way people are messing them up are if they are pushing the Butterfly valve to hard closed.
Old Aug 29, 2013 | 10:29 AM
ChrisKG35's Avatar
Did this yesterday, the relearn is not difficult or troublesome AT ALL! Once you bolt the TB back together, just turn your key to ignition for 2 seconds... make sure you hear the butterfly valve open... then remove the key for 10 seconds or more. Done, your car will idle perfectly and your start up problems should vanish. Goodluck!
Old Aug 29, 2013 | 12:03 PM
68_GT's Avatar
I disconnected my positive battery terminal disconnected my intake piping sprayed throttle body cleaner inside and wiped away with a microfiber towel. I also used one finger to open the blade and another to wipe around in there and the edges of the blade. Used a lot of spray / cleaner and several microfiber towels until they wiped clean. I did this because my engine would start then stall out and die. I could see a ridge of carbon build up in there that I was able to eliminate. I didn't even remove the throttle body from the car. I put the positive battery cable back on and started it up and the problem is fixed. I got a high idle for a few minutes while the computer was resetting but then the idle was perfect. Now it starts right up and stays running everytime.
Simple fix ... No relearn mess
Freeman186
Sep 6, 2023 10:07 AM
andy350gt
Sep 19, 2015 08:39 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Chadwick Arnold
Sep 9, 2015 02:59 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
