Engine goes into limp mode intermitently - Codes p2122 p2138 p1229
Old Dec 17, 2013 | 06:03 PM
yoyopol2000's Avatar
Over the past 4 days , my 2004 G35 Coupe has randomly lit the Service engine soon light and gone into limp mode (cant rev higher than ~1500 rpm). Prior to this everything was working normally. The codes that get stored in the Computer are p2122 p2138 p1229. It can happen 3 times in a matter of 20 minutes or go a day without any issues.
ANyone have any ideas on what I should be looking for? Anyone have this happen to them?
Old Dec 20, 2013 | 02:43 PM
So after spending countless hours troubleshooting and tracing wires, i decided to look at all the connectors, cable harnesses, and wires for all the sensors that are associated with trouble code P1229. This includes the Accelerator Pedal Position Sensor, the EVAP Pressure Sensor, the Power Steering Pressure sensor, and the Refrigerant pressure sensor. I found that the harness with the wires that go to the Refrigeration Pressure sensor was rubbing against a piece of the body that the front bumper attaches to ( between the radiator and grille). The White/Blue wire (The one that provides 5 VDC to the sensor) was on its last couple strands of copper, also a black wire had some copper exposed. See pictures and drawings below
Attached Thumbnails Engine goes into limp mode intermitently - Codes p2122 p2138 p1229-img_20131219_184544.jpg   Engine goes into limp mode intermitently - Codes p2122 p2138 p1229-img_20131219_184647.jpg   Engine goes into limp mode intermitently - Codes p2122 p2138 p1229-img_20131219_185856.jpg
Old Dec 20, 2013 | 02:53 PM
Urbanengineer's Avatar
Appreciate you sharing this with us.
Old Dec 20, 2013 | 02:58 PM
WhosUrBuddiee's Avatar
Thank you for posting the information and finding. Hopefully it will help out another member someday.
Old Nov 11, 2022 | 07:58 AM
dante.s's Avatar
grey g35 coupe abd i have the non rev up with a z1 plenum, z1 intake , and z1 throttle body
so I fixed this issue with the wires and it keeps throwing the codes so I tried a new throttle body and it worked for a day and the next morning it pulled the same thing. Does anyone have any idea?
Old Nov 13, 2022 | 11:16 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P2122, P2138 is the APP, not the TB.
P1229 could also be the APP as well.
EDIT: APP = gas pedal, accelerator pedal position switch. Your gas pedal is just an electric switch.
Old Nov 20, 2022 | 10:52 AM
dante.s's Avatar
I fixed the pedal as well and it worked for a day and next morning it didn’t work again
vq_rob07
Apr 19, 2020 04:47 PM
DriftRoundUrMum
Jul 18, 2017 09:11 PM
KevinE
Intake & Exhaust
Apr 19, 2011 05:52 PM
masterdave
Jul 13, 2010 03:53 PM
dualGz
Nov 23, 2007 03:23 PM
