Gas Gauge Problem
Old May 6, 2003 | 08:46 PM
Murrieta_Rob's Avatar
Gas Gauge Problem
Hello. This is my first post. I’ve had my G35 sedan about 2 weeks now and I’ve got a slight problem with my gas gauge. It gets down to about ¼ tank then all of a sudden the needle goes down to empty, the yellow light comes on and the Fuel Economy computer says 0 miles to empty, find a gas station soon. Then over the next 10 minutes or so the needle creeps back up to where it belongs.
Has anyone else seen this? If so, what was the fix? The dealer already looked at the connections around the tank, but they didn’t find anything wrong. I’ve got 1800 miles on it and it’s done this 3 times already.
Thanks,
-Rob
Old May 6, 2003 | 09:10 PM
FDNameBrands's Avatar
Re: Gas Gauge Problem
That happens when you have very low gas, when you are braking all the gas goes to one side of the tank, so the gauge registers empty, because it’s not getting a leveled fuel reading. But this only happens within a few seconds of stopping then it goes up again when the gas levels out in the tank.
Old May 6, 2003 | 10:56 PM
Thank you for the reply, but I don't believe that is the case. Every time it's done it, I've been on the freeway. The gas wasn't that low. 2 of the times the gauge was just above 1/4. It goes down to E within a second or two, but it takes it 10 or so minutes to come back up.
Thanks,
-Rob
Old May 6, 2003 | 11:58 PM
bigel's Avatar
Sounds like the sending unit in the tank
Old May 7, 2003 | 12:02 PM
al503's Avatar
I've seen my needle go down abnormally fast (a quarter of the entire gauge) and go back up again all in the span of 10 or 15 minutes on the freeway. I've never had the problem you've had except for the gas gauge having a totally different reading when I turn off the car and turn it back on.
Old Jun 2, 2003 | 03:35 AM
bw_g35's Avatar
It happened once on my coupe, with a quarter of a tank then the needle drop to empty, then rise it back up, while i was driving on highway.
Old Jun 2, 2003 | 09:31 AM
IQ9's Avatar
IQ9
I haven't had the "empty" problem. I can't get mine full. It will only fill to the mark under full. Dealer says that it is the sending unit but that there is no reason to replace it? Anyone else heard of this problem?
03.5 Sedan/B. Silver/Prem/Winter/Aero/Tint/Rims
69 Chevelle Hard Top BB/4.11's/Posi
Old Jun 2, 2003 | 10:15 AM
Rumble's Avatar
I have not personally run into this problem, but you've done everything correct so far. Maybe some dealerships are not as willing to REALLY check the problem. Try taking the car to another dealership and they should be happy to assist you. Ask for a good dealership wherever you are located in the Regional forums. Maybe someone can help you out from there. Good luck.
It's still a G thang!!
Old Jun 2, 2003 | 02:44 PM
IQ9's Avatar
IQ9
These guys are generally good but I got the service manager. He and I got into it when I bought my car. The tech who preped my car forgot to put the fuse back in,so I had no blinkers,clock or homelink.I called and was directed to him-he said it brand new, there could be nothing wrong as a tech had gone over the car with" a fine tooth comb.". Well, show him I did and fixed it myself in front of him and the sales manager I bought it from. Now he has a I am better than you attitude.
Old Jun 2, 2003 | 09:42 PM
RamboRami's Avatar
G35driver.com Moderator
yeah both of my cars do this too, the fuel indicator is just not very accurate!
(98 Corolla and 03 G35c)
G35c 6MT DG/Willow
Old Jun 3, 2003 | 01:27 PM
Dabearz454's Avatar
ICQ9... i have the exact same problem as u do... to a tee... the only thing that worked for me ONCE, was when i disconnected my batter,, it still does it and when i disconnect now,,, it doesnt get better... i dont know bro, personally i just deal with it,,, thats probably not a good thing though ... try the battery thing i hope it works bro
mtlruss
Dec 20, 2015 01:51 PM
wonderizm
Sep 24, 2015 03:09 AM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
ClwMike
Jul 23, 2015 12:55 PM
