Please Helpp!!!!!!
What up everyone,
I have a problem and I a question.
Problem:
Installed my injen intake yesterday, it works fine sounds nice. I drove my car around all day, no problems what so ever. I had my car turned on (idling) in my girlfriend’s drive way as I ran into to get my cell phone. I came back out and sat in my car and the SERVICE ENGINE SOON light is on. WTF????
Question:
What THE HELL DO I DO TO GET RID OF IT????
PLEASE HELP!!!!!
THANK YOU
Problem:
Question:
PLEASE HELP!!!!!
THANK YOU
its the MAF sensor........did you disconnect the negative battery terminal *before* disconnecting the MAF sensor during the install? You might be lucky and all it is a loose MAF connection. Otherwise, you might have to take it into the service dept. to reset the "check engine" light.
doc
doc
doc
doc
before i take it back to the dealer for service should i try the ECU reset method??
DAMN iight thanks guys for all the help!! im gonna try if it doesnt work... should i worry bout taking it to the dealer service center or should i take to a private service dept.???
doc
doc
pedal method or the battery disconnect. If you take it to the dealer, they
will charge you to clear it. I know about this, as I left my MAF sensor unplugged once.
As soon as I started the car, the check engine light
lit up. I knew immediatly what I had done. So I did the pedal ECU reset and
the light turned off. This is common and easy to fix.
welll,
i think disconnecting the battery for 24 hrs will work..
If not just drive it aorund for a week. It should go off on its own...
I think...
Ed
I think...
Ed
Way back, when I put my Pop-Charger on, I forgot to re-connect the MAF wire prior to starting the car.
The 24 hour re-set didn't work for me. I was told that it would go off after something like 7 or 8 cold start cycles however. It didn't in the 4 days I drove.
Around that time, I bought an OBD II Code reader, so I did the reset with that.
thank for alll the help guys I DID IT!!!
and i only had to unplug it for like 5 seconds.
i unpluged it and then realized that i didnt roll my windows down, so i reconnected it and then went to roll the windows down. when i turned it on the light was off HURRAY!!!
thanks for all your help though
highly APPRECIATED!!!!
w00t!
w00t!
G_Ride.x
Jun 13, 2013 02:06 AM
