Fast Crank won't start
Old Mar 17, 2016 | 11:11 PM
justanothername's Avatar
Hey Everyone, I just ran into an issue. my 03 g35 AT, just shut off while driving and won't start up anymore. When I crank it, it spins really fast. I can see the crank spin when the trying to start. It sounds very different. I don't have a check engine light, or codes or anything.
I am thinking its the timing chain...any ideas? Thanks in advance.
Old Mar 18, 2016 | 03:04 AM
coffeysm's Avatar
Is the red light steady or flashing?
If it's flashing move on otherwise try using another key.
I'd check battery (try jumping it), fuses, relays, air, spark, fuel, and then maybe a crank or camshaft sensor.
Old Mar 18, 2016 | 11:08 AM
I am not sure which red light you mean. I don't have any llights staying on. I did a self diagnostic check to make sure and it was 0000. The battery is brand new and the starter does turn over. I checked the timing chain and tensioner and it is tight with no slack.
If it was a sensor, I believe it should throw a code right?
While I was working on the motor I realized this looks like a compression issue.
I am keeping my fingers crossed that I don't have to pull the motor..
Old Mar 18, 2016 | 01:12 PM
coffeysm's Avatar
The red light right next to the steering wheel, it's your security light.
Old Mar 18, 2016 | 01:51 PM
Oh ok, the security light is not on.
I did a compression test and I am not getting any compression from any cylinders, which was my worst nightmare...
Old Mar 18, 2016 | 03:11 PM
coffeysm's Avatar
You're not getting any compression or low compression?
Old Mar 18, 2016 | 03:50 PM
I am not getting any compression.. it just sits at zero when engine being cranked.
Old Mar 18, 2016 | 11:29 PM
coffeysm's Avatar
You had the accelerator pressed while you did the test right?
Did you run out of oil or low oil? Maybe drain it and see if there is anything in there. Did it overheat at all?
Can you crank it by hand with a breaker bar?
I'd do a leak down test or if you don't have one. Take the shrader valve out of your compression tester, put the cylinder(s) at top dead center, and then listen to see where it leaks. That might be able to tell you if you need new cylinder heads or entire engine.
Old Mar 19, 2016 | 11:19 AM
telcoman's Avatar
Veteran: Army
You found the root cause
Telcoman
Old Jun 13, 2016 | 12:14 PM
well I figured out what it is, the Iron sleeve held up but the aluminum around it on 2 pistons didn't. A couple chunks broke off, which then sent water past the head gasket. Well that sucked..
DEMoLITIoN
Nov 29, 2017 10:41 PM
Thatguysg35
Apr 18, 2016 03:38 PM
Jorgebarrera
Jan 25, 2016 02:42 PM
mattdg35
Jan 20, 2016 09:23 AM
Jorgebarrera
Jan 19, 2016 06:48 PM
