Car won’t start...
Old Apr 10, 2018 | 11:25 PM
Natmats's Avatar
Car won’t start...
99,500 miles
6MT
Here’s some back story of the last couple months w Melody:
- driving in traffic, car died (thought I stalled the car)
- slow to start; about 5 seconds
- self diagnostic showed cam shaft pos sensor
- finally replaced it after a month
- started better. For a while...
- slow start up so thought it was batt
- took it to pep boys, told to charge the batt and hve retested
- charged it by idling car for 1 hour
- started up much faster
- slow start weeks later and didn’t turn over or even crank this am
- bought installed new batt and I hear this noise (link below)
any ideas?
Thanks in advance!
Old Apr 10, 2018 | 11:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Pull off the starter and take it down to have it tested, check the starter drive gear to make sure it's not missing a tooth, sounds like it's not engaging the flywheel though.
Sluggish start problems can be the starter and not just the battery. Make sure to disconnect your battery first so you don't celebrate the 4th of july under your vehicle.
Old Apr 11, 2018 | 12:46 PM
Natmats's Avatar
Thank you! i'm going to pick up a replacement starter today and swap it out tonight. i hope it resolves all these issues!!
i'll keep you posted (haha)
Old Apr 11, 2018 | 12:47 PM
cleric670's Avatar
BANNED!!!
I'd test the existing one first before throwing parts at the car, it might be something as simple as a corroded battery wire or something.
Old Apr 11, 2018 | 12:51 PM
Natmats's Avatar
i checked and cleaned the battery terminals a few months back thinking it was the original issue but to no avail... or are you talking about something different that i would have to investigate underneath the car where the starter is?
thanks,
Old Apr 11, 2018 | 01:12 PM
cleric670's Avatar
BANNED!!!
I mean the connection on the starter might just be all corroded, or the battery cable itself might have a pinhole and the copper is all rotted out somewhere. You can disconnect the cable and use a digital multimeter to read resistance (ohms) across the two ends, the meter should read 0-1 ohm resistance. There's a really good chance it's just the starter though, sluggish starts seems to be a common indicator of wear for them.
Old Apr 11, 2018 | 02:03 PM
Urbanengineer's Avatar
^ I agree.
But the new starter makes the car sound like a race car when it starts . It's the Denso branded starter, I think. $600 less than dealer cost for one less sticker.
Old Apr 11, 2018 | 05:55 PM
cleric670's Avatar
BANNED!!!
I was thinking of just having mine rebuilt when I pull the transmission in a couple months to put in the rebuilt CD009 but I just realized the spec on the Denso starter has an almost 30% higher kW rating...
Old Apr 11, 2018 | 11:07 PM
Natmats's Avatar
Wiring looks fine
Old Apr 12, 2018 | 02:47 AM
Natmats's Avatar
Update!
swapped out the starter and she’s running like it’s 2003!
thanks for all the replies y’all! Can’t thank you enough!
Old Apr 12, 2018 | 01:35 PM
cleric670's Avatar
BANNED!!!
Yeah there is a TON of debris on that starter, if you're a 6MT on the stock clutch you might start preparing for a new one in the near future. Glad everything is working good now.
laratta
14
May 20, 2019 10:30 PM
RemmyZero
Aug 22, 2015 11:38 AM
G Thunder
V36 General Tech Questions
Dec 11, 2013 09:45 AM
venommaxr33
Feb 26, 2006 06:54 PM
theskipps
Dec 9, 2003 06:34 PM
