G35 starts but shut off!
Old Aug 11, 2018 | 09:54 AM
nzedwards's Avatar
I posted link to video. Does anybody know what is happening and how to fix it?
Old Aug 11, 2018 | 12:00 PM
Scorpi0's Avatar
Wtf...why does your car sound like a lawn mower?
Old Aug 11, 2018 | 12:07 PM
nzedwards's Avatar
i believe it is because the cats are off
Old Aug 11, 2018 | 12:40 PM
telcoman's Avatar
Veteran: Army
I believe the vehicle is smarter than the OP and shuts it down to avoid polluting the environment.
Telcoman
Old Aug 11, 2018 | 12:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I suspect it's a failing fuel pump, relay, ecu. Sounds like the engine is priming fuel properly because it does start however if the fuel pump doesn't stay running then it stalls out from lack of fuel. Get the fuel damper sandwich plate from Z1 and install a fuel gauge so you can see what the pressure is doing during a start.
Old Aug 12, 2018 | 01:42 AM
nzedwards's Avatar
Thank you, it is fixed! I cleaned the maf sensor and somebody noticed that a few wires were plugged in the wrong area on passenger side. Car is running but the temperature gauge is a little high. Im assuming it is because the coolant has not finished bleeding.
Old Aug 12, 2018 | 01:45 AM
nzedwards's Avatar
https://youtu.be/O6q_Hg2Ge5w
Direct motor swap btw.
Old Sep 14, 2019 | 01:42 PM
unique serrano's Avatar
What
What was ir that was unplugged. Man ?
[/QUOTE] plesse lmk
Old Sep 14, 2019 | 02:24 PM
nzedwards's Avatar
Originally Posted by unique serrano;[url=tel:7175428
7175428[/url]]What was ir that was unplugged. Man ?
My flywheel was actually misaligned. If your car is doing this, take out the crankshaft sensor and see if car runs.
You should if your coil packs are plugged in the right areas also before doing the first thing i said.
plesse lmk[/QUOTE]
Old Sep 14, 2019 | 02:29 PM
nzedwards's Avatar
[QUOTE=unique serrano;7175428]What was ir that was unplugged. Man ?
Flywheel was misaligned, remove crankshaft sensor and see if car runs.Check if coil packs are connected in right areas also
Old Sep 14, 2019 | 02:34 PM
[QUOTE=nzedwards;7175434]
Coilpacks are in place and which is the crankahaft u referring to ?
please lmk
Freetrade59
May 3, 2017 05:03 PM
LuisGee
Aug 25, 2016 12:19 AM
blue_bomber697
Oct 16, 2014 10:31 PM
pakiplayer421
May 21, 2008 01:40 PM
