My new g35 build.
Old Aug 17, 2019 | 12:33 PM
Waynesg's Avatar
2004 g35 coupe fully built motor (too many mods to list all forged internals) stage 3 fuel system.
My new g35 build.
Just started a new forged internals build, will make a list and things I wanna do, but have a lot of questions, if someone has the time please let me pick your brain for a bit.
Old Sep 19, 2019 | 04:58 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If you do a rods / forged piston build make sure you send the rotating assembly out for a balance so they can remove weight from the crank. The factory service manual will have all of the piston ring and bearing clearances.
Old Nov 24, 2019 | 10:45 AM
Waynesg's Avatar
My
-My forged build as fallows.
-Eagle rods (arp) cap bolts
-JE 8.5:1 fsr pistons
-ACL bearings (main and rod)
-Arp main studs
-Arp L19 headstuds
-Jim wolf oil pan spacer
-radium oil cooler with 10AN lines
-Invidia headers (will be changing to turbo manifolds)
-Invidia test pipes with full invidia Gemini ---header back exhaust
-Dual catch cans (radium )
-new OEM timing chain kit
-Excidy clutch and Jim wolf 16 pound flywheel
-radium triple pump surge tank (lol just incase)
-10,8,6 AN fittings and lines throughout the build
-Stage 3 head porting with 1mm oversized valves from supertec
-ported lower intake
stage 3 return fuel system (trunk mounted surge tank (radium regulator, 10 an fuel lines to 10an radium fuel rails. Way too many parts to list. Link to build is here.
https://linksharing.samsungcloud.com/w3acuBwfDq18
Old Nov 26, 2019 | 10:52 AM
Urbanengineer's Avatar
Is this the speed force build? Nice list!
Old Oct 19, 2020 | 12:03 PM
Waynesg's Avatar
Actually I changed some parts off that list. I went full radium fuel system with Holly double pumps. And in trunk. All 10an. And a list of other parts. Hopefully pic work...
MY G BUILD
1. Rods (eagles h beam) $900
2. Pistons (JE 8.5-1) $1300
3. ARP main studs $250. ARP L19 head studs $800
4. ACL main and rod bearings $400
5. Oil cooler mitshimo $250
6. JW oil pan. Spacer $150
7. Exedy stage 2 clutch and JW 16 pound flywheel $600
8. AEM cold air intake $400
9. Gauges piller $300 with gauges
10. 2x mishmoto catch cans $300 both
11. Energy suspension bushing kit $300 front
12. Headers megan racing $400
13. INVIDIA TEST PIPE $400
14. INVIDIA EXHAUST $1700
15. PlENUM SPACER (BLOX)$100
16. Raduim engineering multi port fuel regulator.$.300.
17. All AN fittings $200 so far
18. 6-8-10 Braided lines. 33' total feet $300
19. More lines and fittings $100.
20. ANOTHER $100 on fittings..
21. Radium engineering fuel pressure gauge. And fitting $100
22 More fittings $100
23 100 for fuel check valve
$12.000 roughly, plus odds and ends
24. Fuel quick release. $100.oo
25 machine work and balance and blueprint $1400.00
26. pre lube pump.$ 200.
27 Timing chain kit $800
28 rev up oil pump $300
29 fuel. Cell/surge tank $100
30 fuel correction kit 100.
30 cosmetic MLS head gasket and full gasket kit $695.00
31Holly dominator fuel pump and fittings. $741.00
Plus 485 for 2 filters and fittings with heat sheild
So far $18.300.00 plus in upgraded top of the line parts
Just some build updates from here in the great north...more pics to come..fuel system upgrade. (Holly duel pump with pre and post filters) Fully built long block. Power/fuse/relay panel in trunk. Rev up oil pump upgrade, too many to list. But heres a few on the new list...
Albanian122
Oct 19, 2020 05:15 PM
G15
Jul 26, 2009 10:51 AM
cpvince
Sep 11, 2007 03:12 AM
Supra
Jul 17, 2007 03:47 PM
