Car will not start no cranking or clicking
Old Dec 11, 2019 | 06:41 PM
CrunkJuice29's Avatar
G35 Coupe
Iv had nothing but problems with my g35 and today after getting my car worked on it will not start. Dash lights will not come on nor the head unit but headlights and power windows will work. From research, i think its the Nissan Anti Theft System because i do not have the factory keyfob that came with the car and i think its in lockdown because it cant recognize the key because its aftermarket. I have it towed to the dealearship right now to get a new keyfob programmed will that fix my problem?
Old Dec 11, 2019 | 08:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Intelligent key or no?
Old Dec 11, 2019 | 08:29 PM
G35 Coupe
No its a 2003 sorry should have specified just been stressing a lot about this now
Old Dec 11, 2019 | 08:31 PM
cleric670's Avatar
BANNED!!!
Also, NATS lockout has nothing to do with the lights on the dash not turning on. If it's a NATS/IVIS lockout the little red light on the left side of the dash will be SOLID RED when trying to crank. If you have no power with the key in the ignition and turned to the ON position then it's probably a relay in the IPDM or a fuse in the fusible link.
Intelligent key you just have to hold the fob directly on the START button when trying to start it, if you try to start without a properly configured ikey there will be a big picture of a lock in the middle of the instrument cluster.
cleric670's Avatar
BANNED!!!
Or someone/something merely disconnected your battery.
Old Dec 11, 2019 | 08:33 PM
G35 Coupe
The battery has full voltage and i am able to turn on the headlights and lock and unlock the car but the dash will not come on nor crank.
Old Dec 11, 2019 | 08:34 PM
G35 Coupe
Do you think it just blew the fuse?
Old Dec 11, 2019 | 08:39 PM
cleric670's Avatar
BANNED!!!
That's where I would start the troubleshooting yeah.
cleric670's Avatar
BANNED!!!
Start by fully inspecting the fusible link. Remove it and check all the fuse holders.
Old Dec 11, 2019 | 08:50 PM
G35 Coupe
But if it was the fusible link wouldn't i get no power at all?
Old Dec 12, 2019 | 12:14 PM
cleric670's Avatar
BANNED!!!
Fusible link is a holder with I think 9 fuses for various electrical systems.
Old Dec 14, 2019 | 07:36 PM
G35 Coupe
Turns out it was my ignition harness it was completely unplugged.
Old Dec 15, 2019 | 07:20 PM
cleric670's Avatar
BANNED!!!
Dohh! Well glad you found the problem.
HareBear
Mar 9, 2019 04:22 PM
needhelp1
Jan 17, 2018 11:56 AM
brazen
May 5, 2013 05:40 PM
Stef
Dec 11, 2010 01:25 AM
AesonVirus
Mar 27, 2007 05:33 PM
