Oil Pan Obliteration (Pls Help!!!)
Old Sep 14, 2021 | 04:10 PM
supkoop's Avatar
GKTech angle kit, H&R springs, Welded diff, Titanium test pipes, Megan racing intake & exhaust
Hey guys I ran over a rock and it obliterated my oil pan, I will have pics attached below. My question is, do you think the upper motor is damaged/seized at all from loss of oil? The motor was running for around 30 seconds after the initial impact. The oil pan was draining oil at a rate comparable to peeing after downing a six pack of beers. After getting out of the car and looking under it I immediately shut off the car and got it towed to my local mechanic, not only is the lower oil pan destroyed, but the upper oil pan was cracked and bent as well, so the subframe needs to come out to repair the car. Would you guys suggest going ahead with the repair? Or do you think the engine was running ling enough for there to be permanent damage. Anyways have a great week, thanks.
Old Sep 14, 2021 | 04:26 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
How did the engine sound during that time between when you hit the "rock" and when the engine was turned off? If you didn't really hear a difference then I'd say you probably caught it in time and minimal or no damage was done.
Old Sep 15, 2021 | 04:25 AM
Scorpi0's Avatar
Engine is fine. Nothing will get damaged that quickly with low oil.
Old Sep 15, 2021 | 03:40 PM
supkoop's Avatar
The engine was running completely fine as if nothing happened. No odd sounds.
Old Sep 17, 2021 | 11:29 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah the engine is probably fine.
Looks like you were overdue for an oil change anyways
No Boost
V36 Engine, Exhaust, Drivetrain & FI
Sep 18, 2021 06:21 PM
Goshko
Jul 15, 2014 12:33 PM
speedcretin
Aug 23, 2012 09:18 AM
denny19
Mar 18, 2012 07:00 PM
theb
Mar 3, 2007 02:46 PM
