Weird slight overheating issues in 04 coupe
Old Sep 12, 2022 | 07:05 PM
discobiscuittt's Avatar
G35 coupe
So i just bought a 04 coupe 6 speed and it handled the 2 hour drive home like a champ but yesterday i noticed the temps started creeping up during normal driving. Previous owner said he "did the coolant system" whatever that means. The temps never hit H and i wouldnt let it happen anyways.
During short trips like to work and back is fine but seems like during idle at a light after a little bit of driving the temps creep up then back down, if im hittin the gas goin 80mph theyll creep, going up hill, and after turning the AC on. I tried burping the coolant today which did let out some bubbles but the screw on the bleeder valve pretty much instantly stripped. I noticed both radiator fans kick on pretty short into driving and they stay on constantly once theyre on. The upper radiator hose gets hot while the bottom does not.
I dont have any idea where to start or what to look for so any help would be greatly appreciated
Old Sep 13, 2022 | 07:14 PM
Scubasteve93's Avatar
Working progress
How many miles do you have on it
Old Sep 13, 2022 | 07:21 PM
G35 coupe
94k miles. Also I should add that the temps do go back down fairly quick. They like fluctuate
Old Sep 13, 2022 | 07:24 PM
Working progress
Mine Broke the first time
Old Sep 13, 2022 | 07:25 PM
Working progress
Did you burp it while it was hot or cold
Old Sep 13, 2022 | 07:29 PM
Working progress
Most people take the radiator cap off first thing in the morning crank it up run the heat on full blast see if any air comes out that way Then Go drive around for a while park turn the heat on full blast and open that bleeder valve that Should get all the air out I And it could be the thermostat not operating right
Old Sep 17, 2022 | 05:55 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'm betting your AC isn't blowing hot air.
G_zus
16
Aug 12, 2023 05:55 PM
MulishaG35
Aug 4, 2021 11:30 AM
charmer37
Feb 12, 2019 04:57 PM
G35stephen
Jul 11, 2018 12:19 PM
kvnmkz7x
Oct 31, 2011 05:08 PM
